Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 06-05-2012, 08:24 PM
07yt1500thunderroad's Avatar
07yt1500thunderroad 07yt1500thunderroad is offline
Vehicle: 2012 passat tdi se w sunroof
Rep:70
07yt1500thunderroad will become famous soon enough
The tires are the same size
I never fired it up until i was done completely with the install.
If this helps the tube size is 1&1/2".
Oh yeah i have the dsp 93 tune.
Old 06-05-2012, 10:14 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
With the tune that's what your getting? Maybe your headers are to big causing a decrease in performance, I thought we should go with 1 3/8 tubing...
-Pat-
Old 06-05-2012, 10:21 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Can you monitor a/f ratio with your tuner? You might be running a bit lean. I'm not sure what could be the issue otherwise...
Sean
Old 06-05-2012, 10:22 PM
snrusnak's Avatar
Rep:1388
You have any other mods?
Sean
Old 06-05-2012, 10:29 PM
BlackHemI's Avatar
Rep:296
Other mods he most likely has is about 10 lbs of boost, from his foot to pedal!!
-Pat-
Old 06-05-2012, 11:19 PM
Rep:3322
If you're running the 93 tune, you'll be leaning out your air/fuel ratio, especially with the headers. I would pick up an AFR gauge (eg. Innovative LM-1) so you can monitor it, but you should really get CMR tune.
