United Radio
Old 06-05-2012, 11:10 AM
rgnbull1227's Avatar
rgnbull1227 rgnbull1227 is offline
Vehicle: 2006 Dodge Ram Mega
Rep:104
rgnbull1227 will become famous soon enoughrgnbull1227 will become famous soon enough
Default Could this be the issue?
I have a 2006 Dodge Mega Cab 5.7 Hemi with 6" Pro Comp Lift and 37" Toyo Open country tires. The previous owner installed a Temp gauge on the A-Pillar. I notice that on the highway, my trans temp is barely registering but if I am going upgrade and the tranny downshifts, the temp starts to rise. If I am towing, it rises quickly.(on steeper inclines at low speed temp gauge has shown 240) Once engine shifts into over drive, the temp drops pretty quick. I heard that if the temp sensor is installed on the tranny fluid line to the cooler, the temps in that line cant skyrocket to 300 degrees and that the temp sensor should be mounted on the tranny itself and not the line. I looked underneath and saw this and took a pic. Is this the reason my temps look higher than they should?
Old 06-05-2012, 01:44 PM
Trim Level: sport
Color: green
Rep:636
i don't have an answer but it sounds like the trans is working fine as temps do change. i would go to a trans shop and ask the same question.
Old 06-05-2012, 02:35 PM
ArmyofOne's Avatar
US Army Retired
Rep:1189
Temps do change, but your tranny temps should NEVER be over 200 on the gauge...EVER. Holy crap! The fluid will reach 2-300 degrees briefly, but if its reading that high its installed in the wrong place. I don't think I have ever seen a trans temp over 150 on the EVIC, and that was towing...way heavier than I should have been.
Is it installed on the hot side or the cold side of the Transmission cooler?
Diesel Technician-PACCAR Inc.
Old 06-07-2012, 12:46 PM
Trim Level: sport
Color: green
Rep:636
army- thats the question he was asking, is it installed on the wrong side, i think he needs to see a trans shop to be sure, rather than fry his trans.
