Old 06-26-2012, 01:19 PM
semlohde's Avatar
semlohde semlohde is offline
Vehicle: 2014 RAM Laramie LongHorn Mega
Trim Level: LaramieLongHorn Mega
Color: bright white
semlohde is on a distinguished road
I'm done with this 430nRHB issue . It will skip and play fast with an iphone4 on Bluetooth streaming unless u press the phone lock button. It will have poor visibility, low brightness, low contrast in daylight (FAR INFERIOR TO THE 730n or ANY other backup camera I've ever seen) that is not controllable. I just drove to my dealer and checked the tsb 08-019-12 and i'm up to date. TA DA DONE! And thanks for all the input.
Old 06-27-2012, 10:53 AM
drew7811's Avatar
drew7811 drew7811 is offline
Vehicle: 2011 Dodge Ram Laramie Crew
drew7811 is on a distinguished road
Originally Posted by xsdbs View Post
1) There is a TSB # 08-019-12 that is available for the 2011 vehicles, it is a revised edition of the TSB from last year, # 08-036-11 rev A.
2) what phone do you have?
3) what are te issues that you're having?
4) Have you tried rebooting your phone? I have seen sevral issues that have "just started" to happen an a simple reboot of the phone helps a lot. I have an iPhone 4S (had a 4 prior to the 4S) and have to reboot them a few times a month for various issues other than just Bluetooth issues. Phones are nothing more than a mini computer and how often do you have to reboot your computer?
5) Have you performed a phone update lately? Did you notice the issues after the update? I have seen new updates affect a phone and Uconnect also.
It's a Samsung Captivate. It does get rebooted fairly often. The issues I keep having are that when I push the Uconnect button it will say the phone is connected (sometimes) and when I tell it to "call so and so" it tells me the "phone is not available". Also when I get an incoming call and I press the uconnect, it doesn't connect. I end up having to pick up the phone itself and turn off the "headset" button to continue with the call. It's not the end of the world, just an annoying quirk that keeps popping up.
Old 07-07-2012, 09:25 AM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
So the TSB for the Uconnect helped withthe iPhone issue, did the dealer also do a radio SW update for the camera issue?
Old 07-07-2012, 09:29 AM
Rep:73
The Captivate did have some issues and I don't 100% recall what they were but I think there was a work around made for the way they were sending the phonebook information and also for the streaming audio. Have you tried the TSB update yet?
edited question:
Did I mess up somewhere? I though that you have a 430N but I was just looking at the PM that you sent me and it mentions a 730N radio and your Captivate. If it is a 730N radio, then the above mentioned TSB won't work for you. It'll only work if the radio is a Mitsubishi radio (RES, REQ, RHB, RBZ).
However I do believe there is a radio update for the Harman radios (730 & 730N) at the mygig website. (http://mofv.com/mygig/) I have more experiance with the Mitsubishi radios.
