Old 06-05-2012, 05:25 PM
chilock chilock is offline
Vehicle: 2011 Ram Big Horn Crew Cab
chilock is on a distinguished road
Default Bilstein qustion need answer ASAP
2011 1500 crew cab. Am in the process of changing to the bilstein adjustable shocks. The directions say to use the bump stop included with the shocks. Problem is none came with it in either box. Do I return them or use oem ones or none at all. I got the truck tore apart and would appreiate some immeidatle help. Thanks.
Old 06-05-2012, 05:32 PM
WhiteHemiTruck's Avatar
WhiteHemiTruck WhiteHemiTruck is offline
Vehicle: 2006 1500 Q cab
Color: WHITE
WhiteHemiTruck is on a distinguished road
I would first call the place you got them from and c if they will send them to u. if not it's your call to return them. if not in my mind the stock bump stops are better then none at all. hope that helps a little
Old 06-05-2012, 06:09 PM
I called them and they said they should have for sure been in the box. They tried to contact bilstein in Vest Virginia? and they are closed. Said He will call me first thing to get them out. Just odd that both shock boxes would be missing them????????
Time to put it back together =(.
Oh well gonna have a beer. Still debating on the 2.8 setting or the 2.1. I dont want it nose up but could always add some rear spacers if need be =)
Old 06-05-2012, 09:02 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Go 2.8" for sure. Their gonna settle and you won't have the full lift amount anyhow
[CENTER][SIGPIC][/SIGPIC]
Old 06-06-2012, 01:36 PM
2.8 it is. Bump stops will be here Friday..........It will be a busy Friday night.
