Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy
loads with coil springs
. Fits all 2009-15 RAM 1500 including Ecodiesel and 2014-15 RAM 2500!
No modification required
; keep the coil springs. TLC also makes units for 02-13 RAM 2500 & 02-15 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™. Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 06-05-2012, 10:54 PM
fattirewilly's Avatar
fattirewilly fattirewilly is offline
Vehicle: 2011 Ram Quadcab 4x4 Hemi Auto
Trim Level: Outdoorsman
Color: White over Gray
fattirewilly is on a distinguished road
Default TLC compressor question
If you opt for the compressor option, does this have the ability to also air up a tire, inflatable mattress while camping, etc.??
Thanks.
Old 06-06-2012, 01:44 AM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default TLC uses Viair 100-C Compressor
TLC comes with the Viair 100-C compressor with Omega bracket (no braided hose) which Viair says is intended to fill air tanks, not tires. Not sure about the air mattresses.
Here is the info from the Viair website on the "C" model v. "H" model which is for filling tires www.viair.com
C MODEL COMPRESSORS - 12 & 24-Volt (Use with Reservoir Tank)
VIAIR “C” model compressors are intended to fill air tanks. They are not equipped with an ON/OFF switch or pressure sensitive shutoff device of any kind. The use of a pressure switch and relay are recommended and required. All “C” model VIAIR compressors (except certain 90 & 100 series units) are equipped with a stainless steel braided leader hose and a check valve to keep the compressor from restarting under pressure which can create an amp draw spike and can cause motor damage. Most VIAIR compressors are equipped with a thermal overload protector that will shut down the unit when overheated. When cool, the compressor will automatically restart as normal.
HARDMOUNT COMPRESSORS (Tire Fill)
The function of a VIAIR “H” model compressor is to fill tires with the use of an air line and an open-end air chuck such as P/N 00025, 00027 & 00029. Please note, all air chucks used with “H” model compressors must be an “open-ended” type that allow air to pass through them freely. A close-ended air chuck will hold air back, which will damage the compressor and will cause the air line to rupture, which can cause injury. All “H” model compressors come with an onboard ON/OFF switch and are equipped with a stainless steel braided leader hose with an open-end quick connect stud installed at the end of the hose. This type of compressor does not come with a check valve, since it is NOT intended to fill air tanks. All “H” model compressors must be installed using the appropriate gauge wiring for the distance from the intended power source and must be properly fused to protect the unit and the vehicle it is installed inside of. All VIAIR compressors are equipped with a thermal overload protector that will shut down the unit when overheated. When cool, the compressor will automatically restart as normal.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500
Level Every Load with TotalLoadControl.com
