TLC airbag question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 06-05-2012, 11:05 PM
Bluebee Bluebee is offline
Bluebee is on a distinguished road
Default TLC airbag question
Started installing this tonight. The kit is good and directions are rather simple, a good thing. That said I have a question on the Airbag on the driver side, it rubs against the coil spring, is this by design, seems off to me? I would have PM'd this question but I don't have that access yet. Appreciate any insights or pictures from those that have installed this on the drivers side....other than that this is a nice kit.
Old 06-06-2012, 01:54 AM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default A turn of the coil spring
We have run into this once before and the fix was simply turning the coil spring about 1/4 turn.
Probably the easiest fix is to put the truck on a lift to let the wheels down to free up the coils and turn them.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 06-07-2012, 02:09 AM
I thought that might be the case. I will try it this weekend after work and throw it on the rack to see if repositioning takes care of the issue. Also just curious but why not leave the yellow stopper in, just cut it down to size, wouldn't this give a better surface area for the bag to butt against?
