Old 06-07-2012, 11:57 AM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
Default Timing Chain with Cam Swap
Hey guys I am going to get a new timing chain to install with the cam swap. Is a stock replacement good or is there an upgraded one anyone recommends? Thanks!
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 06-07-2012, 02:54 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Could swap to a 6.1 timing setup if not a stock replacement will be fine
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 06-07-2012, 03:15 PM
Color: RED<----
Rep:15
Any advantage with the 6.1? Stronger im guessing? Wont wear out as quick?
Old 06-07-2012, 03:31 PM
Color: RED<----
Rep:15
Any advantage with the 6.1? Stronger im guessing? Wont wear out as quick? Is it a direct replacement?
Old 06-07-2012, 07:40 PM
irnwkrkev irnwkrkev is offline
Vehicle: 2011
Trim Level: Longhorn
irnwkrkev is on a distinguished road
The gen 4 5.7 and 6.4 share the same part number for timing chain and tensioners. Not sure about the 6.1 or gen 3 5.7's
Old 06-07-2012, 08:46 PM
I push the skinny pedal
Rep:3277
Are you running/planning to run a supercharger? That's about the only reason I could see swapping the timing system. After discussing with Alex w/ Arrington and Stu w/ Inertia about my build, they both recommended I stick with the stock timing chain and just pin the crank when I get over 500rwhp. The only real upgrade is a double roller timing chain and that's a substantial investment unless you absolutely need it.
I would not swap to a 6.1L chain/tensioner as the 6.1L guys have been swapping out for the 5.7L tensioner because it doesn't wear out as quickly.
Kurtis
Old 06-07-2012, 09:16 PM
Color: RED<----
Rep:15
Cool stock it is works for me!!!
