2012 express 13.3! - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 06-08-2012, 01:59 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
http://ramforumz.com/showthread.php?...t=line+booster
Post #5 explains how it works.
Sean
Old 06-08-2012, 02:40 PM
dusterman dusterman is offline
Vehicle: 2012 ram reg cab express
Rep:79
dusterman will become famous soon enough
thanks read it.. doesnt sound like a good thing to have
Performance:K&n cai, muffler delete, ported throttle body, 2800 edge stall 180t and white lightning tuning : soon longtubes
Interior: painted inserts, clazzio leather kit.
Old 06-08-2012, 02:43 PM
snrusnak's Avatar
Rep:1388
Some say it is, some say it isn't. I say it isn't. IMO it does nothing at best.
Sean
Old 06-08-2012, 08:42 PM
hemiexp04 hemiexp04 is offline
Vehicle: 2014 blacktop qq 4wd 8speed
hemiexp04 is on a distinguished road
I personally like it..firmed up my shifts a little bit..for 50 bucks what do u expect
Old 06-08-2012, 08:51 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
you got track slips and dont think youll hit 12's since you cant go over 105
Old 06-08-2012, 08:58 PM
snrusnak's Avatar
Rep:1388
That's pretty much my point. These resistor tricks worked 20 years ago on the very simple computer systems all the way through OBDI systems pretty much, but these newer systems are very complex and have a lot of redundancy. Tricking one sensor is pretty much useless as there are multiple sensors monitoring identical values and the other sensors that will still correct the values to what they should be. At best you will get a temporary change.
Sean
Old 06-08-2012, 10:18 PM
yes..ill post pics of slips and vids of my two runs..Fitsy run was a 13.6 with a 2.2 60ft @100mph and the next run was a 13.3 with a 2.0 60ft at 96mph? Idk how i only ran 96 mph but oh well only care abt ets..and yeah im with you on the high 12s, itll be really hard cause im already hitting the limiter at 100mph cause the 22in viper wheels messed my speedo up.
Old 06-08-2012, 10:21 PM
totally agree with you but for now it wrks so im keepin it.
Old 06-08-2012, 10:26 PM
snrusnak's Avatar
Rep:1388
timmy had a good idea that for the drag racers you could install it for the track only. You'd maybe get firmer shifts that night. But then when you remove it you'd have to do the relearn or else have "soft" shifts temporarily that could wear the clutches faster.
I dunno, you guys have much more power than I do(I'm lucky to run a 15.9, probably 350hp and that might be over generous), but my truck shifts pretty firm as is. The more power you have, the harder it is to get it to the ground. I do have the trans tuning with the SC tuner though...
Just be aware(if you didn't know) that you should do the relearn procedure upon removing it. If you don't you will have too low of line pressure values and will temporarily have "soft" shifts until it adjusts back to normal. I'm not positive but would think this would wear the clutches faster. Probably wouldn't matter if it was one time but if you did end up doing this only at the track a lot it'd reduce clutch life.
Sean
Old 06-09-2012, 12:19 AM
dodgert's Avatar
Trim Level: rt
Rep:1061
i just got 20's with slicks cant wait to get to the track soon
