Old 06-12-2012, 10:00 PM
Vehicle: N/A
Rep:1045
Ya know... could make the cow catcher up front a qwik connect so you could run a plow in the winter ....
Old 06-13-2012, 09:50 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
All I could find were air horns...and if I'm going to put them on...well then I'm not going to go off the shelf, I'm gonna need a compressor...
Well if you're trying to be authentic, then an air horn is the way to go LOL
I've seen a couple of locomotives with an electric whistle, but most of 'em are air horns that are electrically activated... very few have the pull cord anymore
Exco
Bill
Old 06-14-2012, 09:15 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Default Where to put the smoke stack
I got a little time to work on it outside (no rain today...Yaaay)
I mounted the headlight
I'm going to shorten the stack a little but I'm not entirely sure where to place it.
I like it way up front:
But thought about more to the middle:
Any input would be appreciated.
Old 06-14-2012, 09:21 PM
Vehicle: 95
Rep:1776
Have a plan for that. Gonna weld 3/4 conduit to the sides and make the cow catcher out of 1/2 conduit. The 1/2 will slide into the 3/4 down the sides of the frame and I'll put pins in the back.
We had the exact same idea...only different!
Old 06-15-2012, 01:05 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Stack to the front! Just looks wrong in the middle.
Like the cow catcher qwik release idea. Conduit is perfect for that. Cheap, easy to work with and very light weight.
brad
Interested in one of my mods?
Old 06-15-2012, 08:11 AM
Vehicle: N/A
Rep:1045
Yup! Up in front looks the best.
Old 06-15-2012, 08:53 PM
Vehicle: 95
Rep:1776
Any tips on welding ^#%@*( conduit with a buzz box arc welder??? 1/64 rod??
I welded one part and then the other side just won't hold so I'm gonna have to grind all the crap back off and try again tomorrow.
Old 06-16-2012, 01:24 AM
brad12kx's Avatar
Rep:2581
Use the thinnest 7018 rod you can find. Keep turning the voltage down until the rod sticks every time you strike an arc. Then keep trying and trying until you learn how to keep the arc going.......this could take awhile. I usually end up at about 32V. 40 on a really bad day, and the welds show it.
brad
Old 06-16-2012, 07:13 AM
Vehicle: 95
Rep:1776
This is one of those 50 amp welders and It sticks once or twice and then arcs well. Should I weld is fast or slow? I think I did the one side pretty quick and then maybe built up too much slag on the other side. I'd get it done and it'd look good. Let it cool off and then it wiggles and cracks then comes apart at the exact same place.
So I walked away for the night.
Old 06-16-2012, 10:30 AM
Excoastie's Avatar
Rep:1358
Is there any way that you can grind the ends of the conduit, in order to get a better fit before you weld? If it's sitting flush, or almost flush, it'll probably be easier to weld
just a thought
Exco
Bill
