Old 06-10-2012, 12:52 PM
k9viper k9viper is offline
Vehicle: 2002 ram 1500 4x4 quad cab
k9viper is on a distinguished road
Default 2002 5.9 magnum intake manifold
The gasket blew on factory intake i dont want to have to redo it in a few years. looking t lowest price aftermarket intake manifold i can any help would be great Thanks
Old 06-18-2012, 01:55 AM
ScottLC's Avatar
ScottLC ScottLC is offline
Vehicle: 1998 1500
Rep:48
ScottLC is on a distinguished road
You mean the plenum fix? There's a permanent fix out there...
http://www.hughesengines.com/Index/p...=&partid=27091
Which is also a good time to do the Kegger Mod and trim up the TB horns. But if you do that you'll have around $200 in your stock intake...or you can spend $600 on everything you need for a real improvement...
http://www.hughesengines.com/Index/p...=&partid=24773
There are no "cheap" intakes for these. Even making the stock one worth a damn is as much as a decent SBC intake.
[CENTER][URL="http://www.ramforumz.com/www.libertydwells.com"]www.libertydwells.com[/URL]
[COLOR=Blue][B]"Once the monkeys learn they can vote themselves bananas, they'll never climb another tree." [/B][/COLOR][SIZE=1]- Heinlein[/SIZE]
[/CENTER]
Old 06-18-2012, 10:53 PM
mamasboy mamasboy is offline
Vehicle: 2012 Ram Sport cc
Color: pearl Blue
mamasboy is on a distinguished road
might look into getting the 4brl m-1 intake as this is cheaper then the 2brl,,plus you can always get the adapter plate for it and run you stock throttle body- some people say you lose a little bottom end,,some say you don't
Old 06-19-2012, 01:19 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Actually, the permanent fix to the stocker is to have the plate welded. Take it to the local welding vo-tech center and get it done for free. Otherwise, the aftermarket plenum plate as mentioned. Any aftermarket replacement will be around $300 or more.
Old 06-19-2012, 06:59 PM
Color: pearl Blue
yeah just hae to be careful welding these as they're cast aren't they?tig should work,,
Old 06-20-2012, 04:32 PM
ScottLC's Avatar
Vehicle: 1998 1500
Rep:48
Any investment in the stock kegger is a waste of money unless that's all you can afford or there's no desire to do anything with the truck other than the absolute basics. I'd planned on modding it, buying the Hughes plate, etc but by the time you buy the bits and pieces and invest your time you're into it for a couple hundred at least. And you haven't really accomplished anything but fix a leak and make the thing look nicer(assuming one takes the time to clean it/paint it).
The m-1 intake is cheaper but it's just an intake. The Hughes flows a little better and comes as a complete set. By the time you buy what you need for the M1 you're into the same price range after doing all the leg work. These intakes don't cost any more to make than one for a SBC, but since they are all that's out there it's a sellers market.
[/CENTER]
Old 06-20-2012, 10:52 PM
Color: pearl Blue
keep an eye out and you can pick up a 2brl m-1 intake for 350 bucks,,just need to look around- the gasket kit is just a phone call to the dealer,,
Old 06-22-2012, 02:10 PM
Thanks guys I just want to do it 1 time and right looking at an intake on sale threw jegs of if any one know of a used aftermarket intake. trying to get as close as i can to a direct replacement thanks again..
Old 06-22-2012, 02:12 PM
forgot to add its the P5007790 if any one knows of it
