Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Place your Ad Here!
Old 06-10-2012, 09:58 PM
5.7ram's Avatar
5.7ram 5.7ram is offline
Vehicle: 2010
5.7ram is on a distinguished road
Default Door Squeaking
So my ram is 7 month old and not only the paint is all chipped in the hinges but both front doors squeak opening and close. I took it to the dealer and they told me it's wear and tear.
2011 Dodge Ram CC Sport Hemi. / 4300 Hid's Top & Bottom / Tints / 24' Kmc Slide's w Toyo's / BellTech 2/4.
Old 06-10-2012, 10:06 PM
Ninjabootsampler Ninjabootsampler is offline
Vehicle: 2011 ram 1500 c/c
Trim Level: Slt plus package
Color: Mineral gray
Ninjabootsampler is on a distinguished road
I had the squeaky door issue after having my ram for only one month. I just put some grease into the roller on the door stop and a year later it still does not squeak
Old 06-10-2012, 10:34 PM
Actionjackson's Avatar
Actionjackson Actionjackson is offline
Vehicle: 2015
Trim Level: Slt
Color: Yellow
Actionjackson is on a distinguished road
I grease mine once a month if not it squeakes.
2015 Slt crew cab "detonator yellow" on 26's
2015 XTS Cadillac "wife's grocery getter"
Old 06-11-2012, 12:37 AM
HTXRT's Avatar
HTXRT HTXRT is offline
Vehicle: 2009 dodge ram R/T
Trim Level: R/T
Color: inferno red
HTXRT is on a distinguished road
i also have to grease them once a month...
Old 06-11-2012, 07:18 AM
Blackthunder's Avatar
Blackthunder Blackthunder is offline
Vehicle: 2011 Dodge Ram 2500 HD
Blackthunder is on a distinguished road
As said above, a squirt of white lithium grease on the rollers makes them nice and quiet again.
Old 06-11-2012, 02:28 PM
tguil tguil is offline
Vehicle: 2012 Ram
Trim Level: Big Horn Quad Cab
Rep:45
tguil is on a distinguished road
As far as he chipping...the truck is painted with the doors attached. The door are then removed for installation of all the interior stuff. As soon as that is done, the doors are reinstalled. Wrenches chip paint.
2012 White Hemi 1500 QC, 4X4, Big Horn Edition, Protection Group, Luxury Group, 3.92 Anti-Spin, Mopar Bedliner, Mopar Tubular Side Steps, Mopar Molded Mud Guards, Access Roll Up Tonneau, Michelin LTX AT 2's
Old 06-11-2012, 03:08 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
It's regular maintenance to oil the door hinges(and many other hinges and latches throughout the truck). The more you lube it up, the less it will need it. Mine used to sqeak a week after I lubed it. Then it was a month. Now I can go several months without lube, then when it squeaks I give it some more lube.
As far as the paint chipping, it's a metal on metal contact area, of course the paint is going to chip there, it's pretty typical.
It's cheap, easy, and quick maintenance. Also, the lube for the hinge to keep it from squeaking will keep any rust from developing where the paint is chipped.
Sean
5.7ram's Avatar
Vehicle: 2010
thanks for the info guys.
Old 06-21-2012, 01:13 PM
Fido Fido is offline
Vehicle: 2009 Dodge Ram 1500 Hemi
Color: Blue
Fido is on a distinguished road
Interestingly enough, mine squeak only in the heat and no amount or type of lube or grease will silence it. Front and back doors on drivers side only. Those are the doors I use all the time.
Tried so far:
Chassis grease,
DW40
Silicon spray
Machine oil
I also cleaned them before applying the new stuff.
Again, it's only in temperatures above 25 Celsius when the truck sits in the sun.
Another interesting topic. My rear drivers side door rubbed through the paint on the cab. The outer rubber seal to be exact. The stealer adjusted the door slightly and they had it touch up painted on warranty just at the end of the 3 year body warranty period. Now I have the same door different spot rubbing. We'll see what we do about that.
Old 06-23-2012, 12:53 AM
azsnow's Avatar
azsnow azsnow is offline
Trim Level: TRX4
azsnow is on a distinguished road
My drivers door is noisy as hell! I looked at the hinges, and the door flexes a ton at the mounting point when opening or closing. It also flexes and makes noise when the window is up and the door is closed if you put any weight...such as an arm on the armrest. The bodies of these trucks are so cheap and thin!
"Its ok, cause balloon boys dad is in jail!"-Ned from BBTLS
