Squeek in Suspension (bad strutt?) - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 06-11-2012, 08:32 AM
RichJHU's Avatar
RichJHU RichJHU is offline
Trim Level: SLT 4WD
Rep:89
RichJHU will become famous soon enough
Default Squeek in Suspension (bad strutt?)
I have a squeek in my suspension that I have been trying to get fixed. It sounds like a break sensor when your pads are low. You know that hight pitched squeek that's really anoying?!!!
But it happends any time i hit the slightest bump in the road.
1st trip to the dealer:
-Getting an oil change and I told them about the squeek.
-They changed the oil but were unable to hear the squeek.
2nd trip to the dealer:
-Getting another oil change and had a technician take a ride with me so he could hear the squeek.
-Changed oil but were unable to find the cause of the squeek. They put grease on all joints in hopes that that would fix it.
3rd trip to the dealer:
-Just about the squeek
-They Replaced all of my brake hardware. Even though I told them it was not the brakes.
-Sounded fine leaving the dealer, but the squeek returned 1/4 mile down the road.
4th trip to the dealer:
-I was able to rock the truck back and forth, while it was sitting still, to show them the squeek.
-They replace the front drivers side strutt assembly.
-The squeek in the front is gone!
-Now I have notices a similar squeek in the rear!!!!!
Does anyone else out there have an anoying squeek in there suspension?
Should I have them replace the rear shocks?
Is this common in the 4th gens?
Old 06-13-2012, 01:21 AM
Nova5757's Avatar
Nova5757 Nova5757 is offline
Vehicle: 2012 Dodge Ram Sport CC 4x4
Rep:18
Nova5757 is on a distinguished road
Had the same problem last week! Removed Factory Shocks and installed Bilstein....Problem solved. Factory shocked failed after 3,000 miles!
Old 10-25-2012, 11:11 PM
chadt256 chadt256 is offline
Vehicle: 2010 ram laramie
Trim Level: laramie
Color: brown/tan
chadt256 is on a distinguished road
I know this is an old thread, but im having the same issues with mine!it is a 2010 and it is coming from the front, like from the struts or upper ball joints
Old 10-26-2012, 01:15 AM
99gp's Avatar
99gp 99gp is offline
Vehicle: 2004 Dodge Ram 1500
Rep:155
I had a bad squeak on on my 03, and it was my lower ball joints
Old 10-26-2012, 07:25 AM
RichJHU's Avatar
Trim Level: SLT 4WD
Rep:89
The squeek came back! I took it back in and they replaces both front strutt assemblies and rear shocks. Been driving it for the past 2 months and everything sounds and works great. I hope it stays that way!
Old 10-26-2012, 04:39 PM
Trim Level: laramie
Color: brown/tan
Alright, I'm gonna order the top gun 2.8 kit for the front & new coils & shocks for the rear.
& replace upper ball joints while doing procedure.
Old 10-31-2012, 05:59 PM
Trim Level: laramie
Color: brown/tan
I've done a little more research on my truck with this noise, if its parked and I grab the door and push up and down you can hear it in the front, I just can't determine if its my struts or ball joints? It sounds just like a sensor on your brake pads when driving and hitting bumps, but it never gets louder it just gets more consistent on like a bumpy or dirt road, and is very annoying. Can't ride with the windows down anymore! Drives me nuts. If anyone has any suggestions I'd appreciate it. Thanks
Old 10-31-2012, 07:15 PM
99gp's Avatar
Rep:155
When my ball joints went out, I could stand on my front bumper and rock the truck and it would squeak squeak
