Old 06-11-2012, 01:13 PM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
Default Replacing timing chain vs whole assembly
When replacing the chain is it acceptable to just replace the chain alone or while its open is it worth spending the extra money and getting the whole assembly?
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 06-11-2012, 02:37 PM
Color: RED<----
Rep:15
I was talking to some gear heads I know said to change the assembly and if I can get a roller timing chain that it will help a little. I found this one, the stock replacement assembly is i believe 120 or so this is 200 but its a double roller? http://www.shophemi.com/p-1237-chrys...by-manley.aspx anybody like what they see? He says its not liek a huge difference but lasts longer and may help gain slight power
Old 06-11-2012, 06:30 PM
irnwkrkev irnwkrkev is offline
Vehicle: 2011
Trim Level: Longhorn
irnwkrkev is on a distinguished road
Do the whole assembly. From what I've read the chain doesn't stretch so much as the gears wear. It's not a huge price increase.
Carefull with a double roller as sometimes they require an oil pump spacer and clearancing (grinding) of the front cover.
Old 06-11-2012, 10:26 PM
Color: RED<----
Rep:15
Really okay great thanks for the info I'll have to check into it more
Old 06-11-2012, 11:54 PM
I push the skinny pedal
Rep:3277
The double rollers do require quite a bit of modification to make them fit so unless you're running a supercharger that puts a lot of stress on your crank then you won't see any real benefit.
You can reuse the chain with no problems, what begins to go on these motors is the chain's slide tensioner. The OEM ones are crap but there's nothing better out there, so we can only replace them with OEM ones. Some people have swapped to the 6.1L slider and they've lasted through some serious punishment but they still wear out and need to be replaced. I have never heard of the gears wearing down, ever, even on the high horsepower LX builds, so I don't know where you heard that, but there is many documented cases of the slider tensioner failing.
Kurtis
Old 06-12-2012, 07:06 AM
Color: RED<----
Rep:15
Okay I will go with the stock replacement thanks dude
