Old 06-11-2012, 04:32 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Default Adjustable Panhard bars!
For those of you that want to center up your rear axle and don't want to use a relocation bracket or drill a new hole here is a better option. Below are two links I found for adjustable panhard bars.
I bought the 1.25" diameter custom adjustable poly ended one from Spohns for $140. The Dallas hotrod bar is only $120 shipped but it's a 1" bar like the factory one.
http://www.spohn.net/shop/Custom-Par...d-Torque-Arms/
http://www.dallashotrodparts.com/09updodgepanhard.html
Old 06-11-2012, 04:42 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Nice finds!
I agree 1" is not real great, especially with an adjuster in there that is even thinner.
So the one you got, it is "custom", right? Not specifically for the ram like the other one is?
Sean
Old 06-11-2012, 06:22 PM
CHVYKLR's Avatar
Rep:252
correct. They are even going to weld the bar slightly offset so it doesn't come in contact with my diff cover.
Old 06-11-2012, 06:24 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I need one of these...thanks man!!!
Have you made the measurements for what we would need?
Old 06-11-2012, 06:33 PM
Jayincali's Avatar
Jayincali Jayincali is offline
Vehicle: 2014 Dodge Ram 8 Speed 3.92
Color: Deep Cherry Red Crystal Peral
Rep:95
Jayincali will become famous soon enough
Sorry for the stupid question, but would I need this if I cut the rear coils to level it? It sits 2" lower in the rear now. Would one wheel be pushed out from the wheel well farther than the other?
Old 06-11-2012, 06:45 PM
CHVYKLR's Avatar
Rep:252
tape a piece of string on your fender so it hangs down to the center of your wheel. measure how much space is between the string and wheel. do this for both side of the truck and you'll know if your axle is centered.
if it's way off you'll be able to tell just by looking at it. I don't think it would have moved much with a 2" drop.
Old 06-11-2012, 07:06 PM
Jayincali's Avatar
Rep:95
Thanks for the info, I'll have to check it out.
Old 06-11-2012, 09:38 PM
BeBeep's Avatar
BeBeep BeBeep is offline
Vehicle: 2010 Ram
Trim Level: R/T
Rep:16
BeBeep is on a distinguished road
I received an email from them today that by the end of the month they will offer an adjustable bar for our trucks. I wonder if it will be offset as well.
2010 Ram R/T - 2011 GWE Challenger SRT8
Old 06-11-2012, 10:08 PM
916Timmy's Avatar
Rep:1443
You talking about Spohn's?
Old 06-11-2012, 10:10 PM
RC DuDe's Avatar
RC DuDe RC DuDe is offline
Vehicle: 2011 Ram 1500
Trim Level: 2WD SLT Crew Cab
RC DuDe is on a distinguished road
I'd recommend the Spohn bar. Solid workmanship and customer service. Easy to get a hold of if needed.
