Old 06-23-2012, 11:20 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
Sorry i'm delinquent on my pics. Bar is installed. I'll post'em up tuesday.
Old 06-24-2012, 06:49 PM
Quicksilver337's Avatar
Quicksilver337 Quicksilver337 is offline
Vehicle: 2016 Ram R/T
Trim Level: 1500 Sport
Quicksilver337 is on a distinguished road
Originally Posted by CHVYKLR View Post
It's here! Very nice gloss black powder coat, poly bushings and zerk fittings at each end. I'll be installing it Monday along with a BT 2/4 kit and Airlift 1000 bags.
That's the same setup I'm going with...please post pics
Thanks for all the info guys I'm going to order my adjustable Panhard Bar as well.
EDIT: Just spoke to Dan @ Spohn and ordered the black adjustable panhard bar. Now I have to wait till the BT 963sp shows up
Old 06-26-2012, 12:25 PM
CHVYKLR's Avatar
Rep:252
Sorry guys I've been running around trying to get ready for deployment and forgot to take some pics. I dropped my truck off with MGH so I'll see if he can take a pic or two.
Old 06-26-2012, 02:54 PM
InDeepWaterBlue's Avatar
Rep:611
That's a horrible excuse jk bud stay safe on deployment, I'll be ordering an adjustable panhard bar as well very soon. When you installed it did you have to actually make any adjustments or was it lined up pretty well "out of the box" so to speak? Also how did you install it, as in how did you lift the truck to install it? I'd imagine the axle would shift when you lift up the truck as well or something. Never had to remove a panhard bar before lol
Old 06-26-2012, 06:25 PM
CHVYKLR's Avatar
Rep:252
It'll show up set to the stock length. I made 2 plumb bobs with string and washers which I taped to the fenders. Install the bar at the stock length. It'll go on no problem. Loosen the jam nuts and rotate the adjuster nut to lengthen the bar. Use the plumb bobs to measure the gaps until both sides look equal. Drop some loc-tite on the threads and tighten your jam nuts. And I did all this with the rear axle sittin on jack stands.
Old 06-26-2012, 08:03 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
When I set my panhard bar up in my camaro we installed the bar, and left the wheels off and put the axle on jackstands to simulate the weight of the truck on the suspension.
Then we measure off of the hubs on the axles to the frame rails.
2011 Big Horn 4x4 -SnowWhite-
Old 06-26-2012, 09:08 PM
Rep:611
Thanks for the info guys
Old 06-27-2012, 04:43 PM
BeBeep's Avatar
BeBeep BeBeep is offline
Vehicle: 2010 Ram
Trim Level: R/T
Rep:16
BeBeep is on a distinguished road
I had my bar installed today and it looks great and works well.
2010 Ram R/T - 2011 GWE Challenger SRT8
Old 06-27-2012, 05:20 PM
SS4Luck's Avatar
Rep:310
Awesome looking piece!!! Good of Spohn to step up to the plate on this one!
Old 06-27-2012, 05:38 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
That bar does look good...I think mine will be red just because!
