Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 06-11-2012, 03:59 PM
00ramdriver 00ramdriver is offline
Vehicle: 2000 dodge ram 1500
Color: maroon
00ramdriver is on a distinguished road
Default 318-360 swap???
I have a 2000 dodge ram 1500 with a burnt up 318 im going to pull the whole engine and replace it with another and was considering the 360 has anyone done this? If so will the bolt up be the same can i still use the same tranny and will I need a new computer? any advice towards this would be greatly appreciated
thanks
-Trevor
Old 06-12-2012, 08:51 PM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
Should have no problem with the change up. The 5.2 and 5.9 are both small blocks so the motor mounts will match, the wiring harness will match, and the transmission will hook up fine. Only change needed is the ecm (computer) so you will need a 360 ecm for that engine. Make sure you get the flex plate from the 5.9 since are externally balance, 5.2 are not.
Old 06-15-2012, 09:04 AM
blknout's Avatar
blknout blknout is offline
Vehicle: 2001 dodge ram 1500 sport
Trim Level: slt with offroad pkg
Color: intense blue pearl
blknout is on a distinguished road
even the stock computer will work also until you felt like upgrading.
