Place your Ad Here!
Old 06-12-2012, 01:00 AM
fastkatanaboy fastkatanaboy is offline
Vehicle: 2005 Dodge Ram 1500 4x4 Quad
Color: red
fastkatanaboy is on a distinguished road
Default If a 2" Torsion (f) & Blocks(r) lift kit causes extra wear??
I just got a 05 1500 QC 4x4 and like everyone here, wants to lift it.
2" is all I really need.
If a 2" Torsion Key (f) & Blocks (r) lift kit causes EXTRA wear on the drivetrain, then why do it?
Seems like it is not worth it.
Or is the extra wear negligible?
Not sure what to do. Please advise.
Thanks!
Old 06-14-2012, 08:49 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
This is by no means an expert response but I'll tell ya what I have learned from reading about lifting our torsion bar trucks.
For one, are you sure you want to raise the front and back by 2"? Only raising the front by about 2" will actually put the truck sitting right about level rather than at the factory nose down slant. Obviously, raising the back as well would keep the slant which I suppose you might want to do if you tow or haul semi-heavy loads frequently.
I don't know a lot about leveling blocks but I don't really see how they would cause any extra wear on your rear suspension.
As far as keys or cranking the torsion bars on the front, the most common side effect I have read about is a slightly stiffer ride. It is possible that you could induce slightly faster wear in the front because you are changing the geometry of the suspension components and therefore how they interact with other components, however, the generally accepted consensus seems to be that if you keep the lift to 2" or less you will be fine. Hope that is some help.
Old 06-17-2012, 01:15 AM
Color: red
I want to lift the rear a bit for towing, maybe I will go 1" instead of 2" in the back.
I thought I had read somewhere that 2" on the FRONT w/ torsion keys (or crank stock ones) results in premature wear.
Old 07-27-2012, 05:24 PM
clbresnyan's Avatar
clbresnyan clbresnyan is offline
clbresnyan is on a distinguished road
the stiffer the ride the uper and lower ball joints are going to take a beating which can wear them out premature. that is all dependent on how much off-roading and rough roads you drive on
Old 07-29-2012, 02:06 AM
11BFollowMe's Avatar
11BFollowMe 11BFollowMe is offline
Vehicle: 2002 Dodge Ram 1500 Sport
Rep:39
11BFollowMe is on a distinguished road
Raised my torsion bars a few years back only wear ive noticed is my right cv boot is tearing a bit thats about it
K&N CAI,Flowmaster Cat-Back Custom Bent With 2.5" Tips,Debadged,Autometer Vacuum Gauge With Single Gauge A-Pillar Pod,Bushwacker Fender Flares,Tonno Pro Tonneau Cover,180 T-Stat,93 Octane SCT Tune,Plasti Dipped Grill and Rims,Tow Mirrors
