Old 01-02-2013, 10:12 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
What are you using to paint this?
Just primer, paint, and clear out of an aerosol can! Just sanded the old paint away first.
Chrome... in moderation.
Old 01-02-2013, 10:15 PM
Any brand in particular of aerosol you're using?
Ill be wanting to paint my vararam lid when it arrives.
Old 01-02-2013, 10:16 PM
Arth's Avatar
Rep:2028
Carrying this over because it is a mod!
Alright to put this one to rest I went ahead and picked up a set of 55W 5k HID's from **************** and installed them into my 2013 headlights.
As the pictures will show these headlights handle the bulb VERY well. I haven't had a chance to drive yet but just from standing back and looking I don't notice glare up close. The HID's give the headlights a bit more premium look I think.
Stock Bulb:
HID Bulb:
HID on the left and stock on the right:
Both HID bulbs installed:
Both HID Output/Cutoff:
The camera doesn't do the headlights justice but they look awesome.
Thoughts and opinions welcome.
Old 01-03-2013, 11:06 PM
Arth's Avatar
Rep:2028
Alright here is the finished product. In all this little project cost me about $40 bucks in supplies and just my time. I used primer, paint, and clear from Autozone and I must say it turned out very well.
Old 01-03-2013, 11:48 PM
Doug, that's looks AMAZING!!!
Was the ain't autozone specific or what what's the brand?
I want to do the same to mine when it arrives.
That is my favorite mod of yours.
With the vararam, I thought the engine cover was removed too?
I like how it's painted...
Old 01-03-2013, 11:52 PM
Arth's Avatar
Rep:2028
Just because I can...
Old 01-03-2013, 11:56 PM
Cause I like what you did with the paint job under the hood
Old 01-04-2013, 12:01 AM
Arth's Avatar
Rep:2028
I used dupli-color for it all. The color I went with was burnt orange with metal specks. Was really easy to do.
For the vararam lid I sanded it down with 320 grit sand paper then went to work with two coats of clear primers...about four coats of paint and one small can. Of clear.
The hemi hat was just primer...a lot of paint then clear.
Yes the cover was supposed to be removed because if you take out the stock air box you lose the crank case breather hose and you have to use the stupid thing that comes in their kit. Since I am keeping the stock air box to make up for the space I got to keep everything the same minus the big intake hose. Makes for an easy install too.
Old 01-04-2013, 12:14 AM
Saved this!!!
We have dupli color here too. I gotta see if they have the paint I want and need. But you make it look so easy and it turned out great.
Old 01-04-2013, 08:31 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Great work Arth, nice paint job, but here I get a little confused, the hose that goes to your original air intake, its the Valve cover Breather, this uses the suction from the vacuum caused by the engine breathing in air through the intake of the old air box, this suction is what pulls the oil fumes out of the Valve cover area and are sucked into the engine intake to be burned. How do those now get sucked in if there is no more vacuum being created by the air intake not being connected to your now disconnected air box? If not using this vacuum to remove the fumes from the valve cover area, why not just remove the old air intake box and dead plug the hose or the valve cover itself? Just wondering?
Oh and the site still wont let me give you reps
