Arth Mod Thread - Page 46 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-04-2013, 10:22 AM
hostyle34 hostyle34 is offline
Vehicle: 2012 Doadge Ram
Color: Sagebrush
Rep:57
hostyle34 will become famous soon enough
Yeah that looks great, keep them coming.
Old 01-04-2013, 11:06 AM
Arth's Avatar
Arth Arth is offline
Vehicle: 2006 Chevrolet Avalanche
Color: Bronze Alloy Metallic
Rep:2035
Great work Arth, nice paint job, but here I get a little confused, the hose that goes to your original air intake, its the Valve cover Breather, this uses the suction from the vacuum caused by the engine breathing in air through the intake of the old air box, this suction is what pulls the oil fumes out of the Valve cover area and are sucked into the engine intake to be burned. How do those now get sucked in if there is no more vacuum being created by the air intake not being connected to your now disconnected air box? If not using this vacuum to remove the fumes from the valve cover area, why not just remove the old air intake box and dead plug the hose or the valve cover itself? Just wondering?
Oh and the site still wont let me give you reps
The vararam kit comes with this thing to block it off but it prevents the use of the hemi hat. I wanted to keep my hemi hat so I just left the air box there because the hose is a tight fit. Besides...a painted air box is better than no air box...?
Chrome... in moderation.
Old 01-04-2013, 11:29 AM
Asur Asur is offline
Vehicle: .
Rep:4373
What if you ran the Valve cover exhaust to the catch can, then you would still have vacuum and it would catch the crap from that valve cover in the catch can? Just a thought. I did not know you lost your hat when installing the Vararam, They should of figured a way to catch that vacuum off the the vararam instead of just blocking it off.
Old 01-04-2013, 11:56 AM
Arth's Avatar
Rep:2035
Honestly if I wanted to I could drill a hole in the small tube next to the air inlet sensor if I REALLY wanted that vacuum but I don't think it is that big of a deal.
Old 01-04-2013, 12:38 PM
Vehicle: .
Rep:4373
Cool, thanks for the heads up, how much room is there next to the air sensor, would not want it all gummed up with oil crap from the Valve cover, or it getting mixed readings from heat being pulled in from the engine?
Old 01-04-2013, 12:58 PM
Vehicle: .
Rep:4373
Never-mind I just seen the pic of the red tube, ya, just across it to the left of the air sensor would be good.
Old 01-04-2013, 01:18 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
This is something I may do....
Just need to find an inlet connector that has a tapered end to slide into a hole and then sort of locks in because of a smaller neck....similar to what is provided with other CAIs like the K&N
sales@revelperformance.com
Old 01-07-2013, 02:19 AM
hemiou812 hemiou812 is offline
Vehicle: 2011 Dodge ram sport crew cab
hemiou812 is on a distinguished road
How much is a set of the new projectors
Old 01-07-2013, 10:41 AM
Revel Performance
Rep:1804
2013?
If so, $500 a piece or there abouts
Old 01-07-2013, 10:53 AM
bighemi04's Avatar
Vehicle: 2017 1500 Laramie
Rep:623
You can find them on ebay for about 500 a pair. Retroshop.com already has corresponding HID kits.
