Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 06-12-2012, 02:09 PM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
Default Transmission problem
This morning I put my truck in reverse to leave for work and the heads up display showed I was in manual 4th. I tried taking it out of manual mode and it wouldn't change from 4th,then I tried shifting thru P, R, N went back to drive and it still was in fourth. And it didn't just read 4th. It was actually in 4th. I could barly get going from a stop. I shut everything down and re-started it, after that everything was normal. Anyone experience this or have any idea why it happened.
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 06-12-2012, 02:32 PM
moparornocar72's Avatar
Rep:630
how quickly did u shift down to reverse after start up??
14.268 @ 95 MPH Full Trim
Old 06-12-2012, 02:39 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I may be wrong but I think that might be "limp mode". Wait to see what transengineer says...
Sean
Old 06-12-2012, 04:00 PM
FDBDW's Avatar
Rep:172
I think pretty quick, I remember the truck kinda jumpin
Old 06-14-2012, 10:55 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
I had this same problem with mine starting at 12,000 miles. Had it to the dealer many times with them trying to repair by throwing parts in it.
For my protection, I filed under the Florida Lemon Law. When the dealer ran out of ideas, they contacted the Star Hotline. My dealer finally fixed it at 25,000 miles.
You MUST get it to the dealer when locked in 4th (really 3rd gear) and don't shut it off until they run a computer check on it, they will never find any codes after the computer clears at shut off.
Have your dealer PM me and I'll give them my Vin to check the records of the tries my dealer made to fix this PITA. It is not normal and can be fixed. I'm now at 40,000 miles.
Good Luck
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 06-19-2012, 08:08 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
what did they fix?
Old 06-21-2012, 09:09 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
Good possibility you need a new shifter assembly, I see similar problems with chrysler minivan shifters and grand cherokee shifters. Haven't really seen any ram shifter problems though...
If your pcm has stored any codes they are stored there untill they are erased with a scan tool so turning the truck off will not erase the codes. Also make sure you didn't accidently put it into autostick mode by moving the shifter from side to side while in drive. I can't tell you how many times people come into the dealer complaining that they are getting bad mileage and the trans isn't shifting because they are in autostick mode and have no clue. I really wish Chrysler would have added another detent that you would have to shift into to get to autostick.
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
Old 06-22-2012, 12:12 PM
FDBDW's Avatar
Rep:172
I dont have my Diablo anymore so I will have to take it by the dealer to see if there is a code stored. I know for sure it wasnt in manual shift mode, that was my first thought when it happend so I tried shifting it up and down manualy and it was stuck in 4th. Not only on the display but the trani to, while driving it wouldnt shift up or down. It would barly move from a stop cause it was lugging so bad being in 4th from a dead stop
Old 06-22-2012, 10:22 PM
Rep:73
I was thinking maybe a TRS (trans range sensor) but if it was actually stuck in fourth gear it's most likely a little deeper in the trans. All chrsyler transmission use solenoid packs, its what actually controls the shifting of the trans instead of a overly complicated valve body like in the old days. Chrysler transmissions are notorious for bad solenoid packs, i can't even count how many I've replaced at work. Sounds like you either have a bad solenoid or bad wiring for the solenoid pack. Either way it should have a code stored.
Check em' out:
Old 06-29-2012, 09:25 PM
Studbuster's Avatar
Rep:61
This is what the dealer did to mine over 13,000 miles. Many trips to dealer.
1- solenoid switch
2- valve body assembly
3- powertrain control module
4- tranduce-pressure sensor
5- had for five days, could not duplicate
6- pump kit & filters
So far so good.
Dave
