Old 06-12-2012, 10:07 PM
lenny09ram lenny09ram is offline
Vehicle: 2009 ram sport
Trim Level: sport
Color: deep water blue pearl
lenny09ram is on a distinguished road
Default 09 sport 2.5 leveling kit, 12.5 what kinda back spacing
i have a 2009 ram 1500 sport. i just installed the rough country 2.5 inch leveling kit. im currently running stock rims and tires. i only have not even a finger between tire and upper control arm. im looking to go with either 33x12.5 or 35x12.5. anyone do this where they know the backspacing or off set to run a 12.5 wide tire? also any suggestions on tire size and brand? primarily looking for a good beach tire
Old 06-15-2012, 05:19 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
If you stick with the same width of wheel (9") then I would go with something with a negative offset- no (zero offset) in order to clear. You're wheels are 20x9 + 18mm offset I believe, and you will need about 1/4" more clearance in order to fit them so that would mean anything in a 9" wide wheel with an offset of +10 or lower should clear. The lower the offset the further the wheels will be pushed out.
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM
