Old 06-14-2012, 08:59 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If you plan on a 180 tstat and some performance mods, colder heat range plugs would be ok, but I couldn't find the correct ones. If you find more info let me know, but definitely be careful with switching plugs around on this engine.
Sean
Old 06-14-2012, 09:10 PM
jammons5126's Avatar
jammons5126 jammons5126 is offline
Vehicle: 2012 Dodge Ram 1500 Crew Cab
Color: Mineral Gray
Rep:49
jammons5126 is on a distinguished road
Where did you get your torque converter at?
I will have to research it some.
Old 06-14-2012, 09:14 PM
snrusnak's Avatar
Rep:1385
I bought it used off another member but it's an edge billet street edge converter. About a 2800 stall. Call edge or circle d, similar products and prices. The converter is a great mod, it's probably the best mod I've done(the tuner is pretty damn good too). Hard to say which is better. But if I could choose only one mod it'd be either the tuner or converter.
And FWIW, if I was buying new I'd ask for a 3000 stall. But 2800 is close enough and considering the money I saved it's great. It's probably better too because I haul a lot of weigh often so the higher the stall the worse off you are towing/hauling.
Sean
Old 06-14-2012, 09:25 PM
Color: Mineral Gray
Rep:49
I hardly ever tow anything or haul heavy things. The only time I haul a bunch of stuff is when I go to work for two weeks. If you don't mind me asking how much did you spend on yours about? I am def looking forward to installing one.
Old 06-14-2012, 09:54 PM
snrusnak's Avatar
Rep:1385
I don't remember exactly, I think $260 or $280. Definitely wasn't over $300. So roughly half price. There is a risk with that though, since there is no warranty and it is possible if the converter is F'd up it could damage the transmission. But I was comfortable with the seller so all was good
Sean
Old 06-14-2012, 10:12 PM
Color: Mineral Gray
Rep:49
thats good. what kind of tranny do we have? I know your truck is a year under mine but is it the 545rfe?
Old 06-14-2012, 10:23 PM
snrusnak's Avatar
Rep:1385
Yeah I think 2011's still had teh 545rfe. Either 2011 or 2012 switched to the new name transmission. It is the same transmission but they renamed it to something like the 65rfe I think. It is the same though, the same converters should work. They just renamed it to call it a "six" speed. Nothing actually changed, all marketing I believe.
Sean
Old 06-14-2012, 10:28 PM
Color: Mineral Gray
Rep:49
yeah i finally found a wiki site to tell me what i had. it showed the 545rfe. it als showed the 65rfe but did state that they were the same pretty much.
I found the edge site and found what they have the my tranny and well here is the link what is the one you think you have.....
http://www.edgeracingconverters.com/...dex&cPath=7_20
Old 06-14-2012, 10:32 PM
snrusnak's Avatar
Rep:1385
Take wiki with a grain of salt. They are identical transmissions, both physically and software. The name is the only difference.
Yes I have the "street edge". Lists at $525.00.
When you talk to them they will ask specifics about the engine, gearing, etc. and any mods or future mods. It all comes into play with the stall. They will sort of "custom" build it to your needs.
I lucked out and got one out of a 3rd gen hemi used that was about a 3000 stall and on my less powerful engine it worked out to about what I wanted which was a 2800 stall.
Sean
Old 06-14-2012, 10:35 PM
Color: Mineral Gray
Rep:49
oh ok. so its best to call them instead of typeing everything in? sorry if there is a bunch of questions your about the only one on my thread right now looking at it. I know when I start doing stuff I will get more people involved. thanks for all the help. you will be the man i come to to ask about this and that lol. reps to you
