Old 06-13-2012, 12:09 AM
goingcrazy goingcrazy is offline
Vehicle: 2011 Dodge Ram
Trim Level: sport
goingcrazy is on a distinguished road
Default lift kit components
I have a 2011 sport crew 4x4. I had a pro-comp leveling kit installed shortly after I bought it and now I need to decide if I want to buy tires or a lift kit. Looking at the rough country 6" kit or a set of 35x12.50x20 toyo's. Both run about the same cost and I'm a mechanic and have installed many kits on Jeeps and Chevy's but never a Ram. On to my question:
looking at the 6" lift kits it would appear as though the front uses a strut spacer along with the lift spindle/knuckle. Am I seeing that correctly? That would mean my leveling kit would be useless since I won't stack them.
I knew I should have bought the Bilstiens instead of the spacers. I really wanted a level or maybe a nose up stance and 37's or even 38's at some point.
Old 06-13-2012, 12:44 AM
4x4Hemi's Avatar
4x4Hemi 4x4Hemi is offline
Vehicle: 2012 Ram 1500 4x4 Hemi
Rep:172
4x4Hemi has a spectacular aura about4x4Hemi has a spectacular aura about
would you have the 6" lift on the stock 20's?
Old 06-13-2012, 09:50 AM
Trim Level: sport
I really like the way the stock wheels look but I don't know if I like them enough to use a spacer. Stock rims with a 35x12.50 requires a spacer and I'm not sure how I feel about that yet. I have no issue with running a 6" lift with stock wheels and tires for another paycheck or two when I would buy the tires.
I'm just trying to figure out if the lift kits use a strut spacer. If they do then I guess I would list my leveling kit on CL to cover the cost of the alignment and just buy bilstiens to get the front up a little more.
Old 06-15-2012, 12:00 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Yes most lift kits especially the 6" use strut spacers
2011 Big Horn 4x4 -SnowWhite-
