Old 06-13-2012, 10:17 PM
10trx4 10trx4 is offline
Vehicle: 2010 Ram TRX4 Hemi
Trim Level: TRX4
10trx4 is on a distinguished road
Default single side exhaust question
Hi Guys,
I have a trx4 with the single side exhaust and I'm wanting to replace the muffler with the 18" magnaflow. My question is, would it be better and cheaper to go the mufflex route or just order the magnaflow and have a local shop weld it in place? Also, if I go with the magnaflow what is the inlet and outlet sizes for the single exhaust?
Thanks
Old 06-13-2012, 11:22 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I'm not sure that mufflex makes a kit for the single exhaust. I think they only make the dual exhaust kits. Single exhaust is 3" diameter. I'd go with the local shop welding it in. You'll never have a leak...
Sean
Old 06-13-2012, 11:38 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Here you go check the Magnaflow Muffler types and sizes. Casing length and inlet/outlet options should provide some choices for you.
Universal
http://www.magnaflow.com/02product/universalmuffler.asp
Glasspack
http://www.magnaflow.com/02product/02glasspack.asp
Race
http://www.magnaflow.com/02product/02race.asp
Old 06-14-2012, 05:30 PM
Trim Level: TRX4
Thanks for all of your help. Do you know if the openings should be center on one side then offset on the other? Or just offset for both?
Old 06-14-2012, 05:32 PM
snrusnak's Avatar
Rep:1385
I'm not sure about that. I'd assume they are inline, so a center/center or offset/offset(same side) would work...
Sean
Old 06-14-2012, 06:32 PM
Color: Satin Orange
Rep:597
center should be fine with the amount of real estate you have to work with. offset is mostly used to counter any space restriction that may hinder the exhaust routing.
