Old 05-21-2012, 03:19 AM
Blakew76 Blakew76 is offline
Vehicle: 2007 Dodge Ram
Blakew76 is on a distinguished road
Default Horn sounds when locking doors
Whenever I lock the doors with the key fob, the horn sounds. I've tried several times following the owners manual to silence it. It doesn't seem work following those directions. Im wondering if I'm missing an obvious step?
Old 05-21-2012, 03:51 AM
918Dodge's Avatar
918Dodge 918Dodge is offline
Color: Metallic Black
Rep:20
918Dodge is on a distinguished road
Does this only occur when you lock the doors? Or does it occur when you open them as well... as if the "factory alarm" is not un-arming with the use of the key fob?
+++++EDIT----- After I read it, I realized my question may not make much sense. so I'll just offer my suggestions.
I do not have a 07 owners manual but I think it goes something like this....
A. Get in the drivers seat and buckle the seat belt
B. Turn on ignition to accessory, do not start the engine.
C. Let 5-11 seconds pass, then press and hold the lock button on the remote.
D. While continuing to hold the lock button, press the unlock button on the remote......
.........You should hear a chime
E. Turn off ignition key
OR Do you have an overhead console? If you do.. I believe it can be done from there... actually i think it HAS to be done from there, if you have one.
Hope this helps
2010 Ram1500/SLT/RCSB/+Hemi
Old 05-21-2012, 08:01 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I also do not have an '07, but I had an '08 prior to my current truck.
It's a matter of getting the timing right on going through the procedure outlined in your owner's manual. It may take a few times, but it does work.
I did this on my '08.
when all else fails, do a search here at the forumz, and I'm sure that you'll get several hits on this topic
good luck
Exco
Bill
Old 05-21-2012, 09:43 AM
HemiLonestar's Avatar
Rep:274
If you have an EVIC, you can can change it through the programming section.
"Big Red"
2006 Charger R/T
Old 05-21-2012, 12:38 PM
I'll try that sequence, thanks! The steps in the manual are: when outside the vehicle, press & hold the lock button, then press the panic button, release both at the same time. I should try the panic button on the remote though, maybe it doesnt work.
Old 05-23-2012, 12:44 AM
I've tried several times, (in vain) to disable the horn upon locking the doors. (following the manual's instructions) & other suggestions. Im assuming it's not possible?
Old 05-23-2012, 02:35 AM
918Dodge's Avatar
Rep:20
I once read somewhere (i think it was google) that there was a particular year of the 3rd gen trucks that you could not disable it. I guess it was 07?? Sorry man.
Old 05-23-2012, 05:17 AM
BigDave52952 BigDave52952 is offline
Vehicle: 2007 Ram 1500 Quad Cab
Color: Inferno Red
Rep:26
BigDave52952 is on a distinguished road
I have an '07 and tried to do what you are asking about. I fallowed the instructions to a tee with 3 different remotes. I could never get it to work. I finally gave up and said the heck with it.
Old 05-24-2012, 10:12 PM
I've given up too. oh well...
Old 06-11-2012, 06:32 PM
I had my truck at the dealer to have another ignition key cut & programmed today, they disabled the horn sounding when locking the doors for me. They were nice enough to not charge me to do that.
