Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 06-14-2012, 02:41 PM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Lightbulb 4th Gen Nitrous
Okay guys got to the point to where i want a huge performance boost. Since i have a 4.7L 2010 regular cab RAM not much Big performance gainers are available (supercharger/turbo ect.). This being said i decided to go after the nitrous idea. These are my thoughts. Please correct me or help me out. I can use all your opinions and suggestions, that be great!
I want to go with a 100 shot window switch from 3000 rpm to 5500rpm. Since a diablosport device "should" allow me to retard my timing ill also have to purchase a predator. I am unsure about the colder plugs is it 2 degrees for every 100HP? I'm new and uneducated to this lol.
What else do i need? what safety devises do i need to purchase along with the nitrous system. also what brand is good to go with. And what are you all's thoughts on this whole idea.
Thanks!
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 06-14-2012, 07:35 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
if you get a zex wet kit..your probably good to go except for colder plugs (ngk4306's).. I run a 150 on mine and i haven't changed anything on the tune side (just colder plugs)
Old 06-14-2012, 07:51 PM
I push the skinny pedal
Rep:3277
If you run colder plugs then you don't need to pull timing, however I would still pick up the programer and use the 87 tune but run premium. I also agree with the zex kit with the window switch.
Kurtis
Old 06-14-2012, 09:46 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Not trying to say your wrong fred, but I'm not sure if you're familiar with the plug setup on the 4.7L. They use different plugs on the lower and upper banks. Lower are iridium and upper are IIRC nickel? I've been told by many people not to F with this lol. I'm not sure what the plug you mentioned is but just wanted to throw this out there.
What if he runs the 87 superchips tune with colder plugs on a 100 wet shot? Should be ok then, right?
I couldn't find colder plugs to the oem ones when I looked. Let me know if you find them. As much as I say I want to stop spending money on my truck, I might consider following your lead with the juice...
Sean
Old 07-06-2012, 04:51 PM
Color: Gloss Black
Rep:141
BUMP!!!
ok so 87 tune on 93 octane fuel?
Old 07-06-2012, 08:06 PM
chefred112's Avatar
Rep:656
I hearya on the 4.7's..different animal but I don't know about using specific plugs..
Old 07-10-2012, 12:57 PM
Color: Gloss Black
Rep:141
May be onto something here guys tell me if im wrong.
OEM plug. http://www.summitracing.com/parts/BCH-FR8TE2/
Colder plug. http://www.summitracing.com/parts/NGK-2460/
Will this work?
Old 07-10-2012, 01:05 PM
snrusnak's Avatar
Rep:1385
I'm not sure that that is correct. Also, keep in mind that's only one plug, you have two per cylinder, and they are different plugs. Going from memory, I think the one you posted there(the bosch nickel yttrium) is intake side, and the exhaust side is a bosch iridium plug.
Sean
Old 07-10-2012, 01:12 PM
Color: Gloss Black
Rep:141
Unhappy
Yes correct that is just for the intake side. That's why I said may be onto something ha
Old 07-10-2012, 01:17 PM
snrusnak's Avatar
Rep:1385
Honestly I'd contact Bosch and see if they can just tell you what plugs are the same but one heat range colder.
After looking at the plugs on their site though, it says "oe/specialty" so maybe they were specially designed for that engine and they are only available in one heat range. I'm not sure of the effects of a different type of plug. If anything I'd try an iridium plug in all 16 holes and see how it runs(monitor mpg, etc.). I THINK the only reason they enhanced the plugs with yttrium was to prolong life. They are getting 50k miles out of a copper plug(enhanced with yttrium). Normally copper plugs only last 30k miles. I don't THINK it has to do with performance.
Sean
