Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 07-18-2012, 10:05 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The plot thickens......
I just noticed that summit's website has the incorrect reach for the OEM intake side plugs for the 4.7L. They list 19mm (~0.75") where Bosch lists ~1.04".
Sean
Old 07-18-2012, 10:07 PM
snrusnak's Avatar
Rep:1385
...and keeps on thickening...
Just emailed armyofone since I know he's changed his intake side plugs on his 4.7L. He says the intake side plugs had only one ground electrode. So I don't know why Bosch lists their own plug as having dual ground electrodes if it actually only has one.
Sean
Old 07-18-2012, 10:43 PM
snrusnak's Avatar
Rep:1385
Sticking with Bosch:
Exhaust:
I'd go with the Iridium
Intake:
I'd go with the Super Plus(which is a yttrium enhanced copper) or the Iridium. Performance should be roughly equal but the Super Plus will probably only last 30-50k miles instead of 75-100k like the Iridium
I'm still looking to figure out what part numbers, but the OEM heat range(Bosch) is 8, so if going with bosch you want to go with a 7 or maybe even 6 for nitrous to get to a colder heat range.
I'll look at NGK's next...
Sean
Old 07-18-2012, 10:53 PM
snrusnak's Avatar
Rep:1385
NGK's website sucks, it's going to be hard for me to come to a decision on an NGK plug since they basically post no info about their plugs(seems like it's all marketing). I'd probably go with the Iridium IX plug for at least the exhaust side though. NGK's equivalent stock heat range for the 4.7 is 5, so to get one heat range colder you'd want a 6.
For the intake side with NGK it's even harder for me to decide but I'd either go with the same Iridium IX or one of their Standard copper plugs(won't last a long time).
I think I'm about done researching this for tonight lol. IMO, at least from the info I found online, I'd stick with the Bosch brand, the plugs available are very close to identical to the OEM type plugs.
Sean
Old 07-24-2012, 10:47 AM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Dam :-/ so no nitrous yet?
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
