Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Chassis - Drive Line - Suspension - Wheels and Tires - LEVELING
Place your Ad Here!
Old 06-14-2012, 06:05 PM
lenny09ram lenny09ram is offline
Vehicle: 2009 ram sport
Trim Level: sport
Color: deep water blue pearl
lenny09ram is on a distinguished road
Default 2.5 leveling kit tire size and backspacing?
i recently installed the rough country 2.5 leveling kit into my truck. im looking to go with bigger tires on 17's. any suggestions what sizes and or backspacing required? looking to go 33x12.5 or 35x12.5
Old 06-19-2012, 03:24 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
For 33's you can use the factory back spacing, and can probably use another 1" wider rim before you need flares
Silence! Differing opinions will not tolerated
Old 07-01-2012, 02:07 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
I have just stock 2wd big horn 1500 with 305/55 on the factory 20 which is a 33x12.10 with only rub at full lock. with the 1.5 front level kit it should fix it so you should have no.problem with 33's but a 35 you may need a aftermarket wheel with5" backspace if I remember right from what my friend had on his 2010 1500 with 2or 2.5" kit. check a couple local shops if you want to be positive.
Old 07-02-2012, 08:55 PM
Cowboy's Avatar
Cowboy Cowboy is offline
Vehicle: 2015 Ram 1500
Trim Level: Express Quad 4x4
Color: Maximum Steel
Rep:14
Cowboy is on a distinguished road
I was actually at the shop today looking for new wheels and tires for my '09 Ram 2wd. Actually looking at 35x12.50x17 ProComp All Terrain Xtreme tires and 17x9 XD Addict wheels. The Addicts what a 5.71in backspace and 18mm offset. Hope that helps some...
2015 Dodge Ram 1500 Express, 5.7 Hemi, 4x4, Maximum Steel, Quad Cab
Old 07-02-2012, 09:52 PM
quadx350's Avatar
quadx350 quadx350 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: SLT Big Horn
Color: Dark Red
quadx350 is on a distinguished road
33's will rub agains the plastic over time and the screws holding in the plastic will come out atleast that's what happend with me no big deal just screwed them back in. but other wise no rubbing part of the problem is i have aftermarket rims that are wider. and they stick out a good amount but with stock rims you should be good to go. i'd go 33's less work and $$ if you go with an after market rims put some screws in the plastic by the fender and your good to go!
interior LEDS, LEDS under seats, Leveling kit, Dick cepek 18 inch rims, 33 inch tires
