Old 06-14-2012, 11:07 PM
majake01 majake01 is offline
Vehicle: 2003 dodge ram 1500 hemi
majake01 is on a distinguished road
Default A/C Blower problem
My A/C blower is giving me fits. At first it would go on and off when I adjusted the steering wheel. Now I have to reach under the steering column cover and push the electrical connecter around and now that is starting not to work. How can I fix this?
Old 06-16-2012, 02:52 PM
Default Picture of the problem
After reading as much as possible here on this forum I decided to throw caution to the wind and get my screwdriver out. I took apart the cover and disconnected the connecter to the ignition and found this. Notice the discoloration between the top two pins.
Where do I go from here?
Old 06-16-2012, 02:56 PM
wheelerfolk's Avatar
wheelerfolk wheelerfolk is offline
Vehicle: 2009 ram 1500
wheelerfolk is on a distinguished road
that is from resistance which builds heat. was the connector loose? that can cause resistance in the circut.
Old 06-16-2012, 10:10 PM
Default Problem solved
New ignition switch, $31.00 at AutoZone. Done! No Mas Problemo!
Old 06-16-2012, 11:15 PM
suh-weeet!!!! Glad you got it.
Old 06-23-2012, 05:18 AM
FTW65W29 FTW65W29 is offline
Vehicle: 2007 Dodge Ram Big Horn
Color: Gray
FTW65W29 is on a distinguished road
Mine likes to fluctuate up and down. At times it barely blows then it decides to come to the party and blow as designed. The blower motor is a year old. Running a continuity test on the resistor pack on Saturday. This truck must have been built on a Friday night as I just replaced 2 of 3 bad door lock actuators.
air conditioner, blower fan, electrical connector
