first track time for the express just sad! - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 06-15-2012, 04:42 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
During closed loop the a/f ratio will remain around stoich(14.7:1). Headers will lean your a/f ratio during open loop(WOT). So when you're on the track running WOT you are running a little lean. Probably not very lean, but you'd benefit from a tune. Without a way to tune and adjust the a/f ratio, there really isn't much you can do.
I'm not really commenting on your times or anything like that, just telling you that with stock tune and long tubes your a/f ratio is a little lean during open loop. And there's not really anything you can do about it unless you tune it.
Sean
Old 06-25-2012, 05:03 PM
roo roo is offline
Vehicle: 2013Express,2014 Charger R/T
Rep:44
roo is on a distinguished road
At WOT, closed loop operation will go into enrichment, richer than 14.7. 14.7 a/f will be at part throttle open loop operation.
Old 06-25-2012, 08:59 PM
1500V10's Avatar
1500V10 1500V10 is offline
Vehicle: 2012 ram 1500
Trim Level: express
Color: true blue pearl
1500V10 is on a distinguished road
At WOT my a/f is around 11.2-11.4, then around 5000 rpm it goes to 10.5. with a 125 hp dry shot the a/f is 12.5
2012 RCSB 2wd Ram express, 12.81@107
Old 07-01-2012, 08:07 PM
snrusnak's Avatar
Rep:1388
You have closed loop and open loop reversed.
Sean
Old 07-04-2012, 08:36 AM
roo roo is offline
Rep:44
Your right, but every gasoline engine goes into enrichment at wot. You can make more power by leaning it out but at the price of higher egt's and the tendency to get into knock. Hard on exhaust valves also.
Old 07-05-2012, 08:32 AM
snrusnak's Avatar
Rep:1388
It doesn't really go into an "enriched" mode at WOT at least not like cold start fuel enrichment, it just goes to open loop and ignores some sensors and reverts to preset fuel and timing maps. Whether those maps are leaner or richer than 14.7:1 depends on how they are written. I'm not sure how most vehicles are stock, I'd assume slightly leaner because at WOT you want more power.
Sean
Old 07-05-2012, 10:58 AM
roo roo is offline
Rep:44
They go rich to avoid knock and very high exhaust temps.
Old 07-12-2012, 02:50 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Put it in manual mode in 1st give it i slight bit of gas at the line just to take the slack out of the drive train and punch it. if it wont spin then that means you have some excellent track prep where you go... Thats not bad for a 2wd what was the DA?
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 07-12-2012, 03:57 PM
JasonRB2k1 JasonRB2k1 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Hemi Express
Color: Mineral Gray
JasonRB2k1 is on a distinguished road
I have no idea how to calculate DA, but it was hot and humid as all get out! I have worked as a dealership tech for the past 12 years, and there is no question in my mind that this is simply a torque management issue. The track prep was almost too good to be honest, but even if I try to launch my truck on some nice backwood road with an empty tank and no traction control on you can just feel the truck bog down as soon as you gun it. Like I mentioned before, I can be driving on dry pavement at 10 mph and it will fight spinning the tires with traction control on, but when you try and do a straigh dig it just bogs all the way down.
Old 07-12-2012, 07:23 PM
snrusnak's Avatar
Rep:1388
It probably is TM. Keep in mind that even with traction control off, it is not 100% off. If you floor it from the get go you might be starting to break the tires loose and the traction control is cutting throttle.
I'd try hammering the pedal to like 1/2-3/4 throttle initially them quickly increase it to full pedal and see if it launches better. It might take several tries to get it down. And it could still of course be something else...
Sean
