Old 06-15-2012, 01:35 PM
thunder98110's Avatar
thunder98110 thunder98110 is offline
Vehicle: 2012 Dodge Ram
Trim Level: ST express
Rep:14
thunder98110 is on a distinguished road
Default si/so with duals trouble
Hi, New guy here but have lurked for a long while. 2012 ram express, 3.92 rear end, drop in filter and fastman tb.
I bought a aero turbine 3030xl thats si/so. I took off the stock pipes and muffler and clamped on the 3030 just dumped under the cab for now. Went to an exhaust shop to see if they could weld it in with my magnaflow ypipe at the end of the turbine for easier install. they told me it would be a ton of work and would be about 4hrs of labor. has anyone here installed a si.so on the dual tip exhaust?? if so, how much did it run you? heres a pic and video.
2012 RCSB, Hemi,3.92,2wd,Fastman TB,180tstat,K&N CAI,AeroTurbine 3030xl + Magnaflow Y,v6efan, LEER 100xl
Old 06-15-2012, 01:47 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:605
Any pictures of the exhaust setup?
Old 06-15-2012, 02:31 PM
Rep:14
here is a video, its the best i could get but hopefully you get the idea.
Old 06-15-2012, 05:08 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
So you have stock dual tailpipes, and want them to weld the y pipe in between that and the single pipe by the muffler?
Go to a different shop, that is extremely easy and should be cheap.
Sean
Old 06-15-2012, 05:21 PM
Rep:14
yup, exactly.
hey snrusnak, you were on DF for a while right? its thunder98110 with the 2gen dak if you remember
Old 06-15-2012, 06:11 PM
Color: Satin Orange
Rep:605
Interesting thinking to get a dual exit out of a SO muffler. The Y pipe is usually to replace the factory Y section that then leads to muffler and then the exit.
Old 06-15-2012, 11:04 PM
snrusnak's Avatar
Rep:1385
yup, exactly.
Yeah man I remember you now that you say that. I don't spend much time there, I do check in every now and then though. I pretty much stick to the Z.
So did you sell the dakota?
Sean
Old 06-15-2012, 11:14 PM
Jchaney579 Jchaney579 is offline
Vehicle: 2012 Ram 1500
Trim Level: Lone Star
Rep:34
Jchaney579 is on a distinguished road
LOL 4 hours and 500 dollars in labor? I had a guy completely weld a custom set of Cherry Bombs. True dual all the way through and delete the Resonators. 2.5 inch pipe with the perfect bends and welds. Been complimented at a couple meets around here in Houston on his work. People saying he is top notch and show/race quility for sure. Took him 42 minutes to do, and part of that was him needing to stop and take a crap because he had just ate lunch. Two Cherry Bomb Extreme Mufflers and a completely custom welded and professionally done true dual setup was 350 dollars. Laugh at that guys face next time you see him. My guy would charge 50 dollars and it would take him longer to put the truck on the lift than it would for him to actually do it.
Old 08-15-2012, 08:14 AM
Rep:14
alright, finally got the exhaust done yesterday after waiting like 3 months. but got it welded up for just over 200, and 2hrs worth of labor. sounds alot different than before.
Old 08-15-2012, 08:20 AM
snrusnak's Avatar
Rep:1385
I'd like to see some pictures as well.
Your truck looks great, I really like the wheels. I really want to get some new wheels, but want to stick with 17's, although those 20's look really good plasti dipped...
Sean
