how to: mount cab lights w/integrated turn signals - Page 12 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 10-07-2012, 12:50 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
If cab lights are for a real man, what should a lady's man do?
brad
Interested in one of my mods?
Old 10-07-2012, 01:31 AM
Vehicle: N/A
Rep:1045
let me rephrase this, EVERYONE should have cab lights. now unless you lower your truck that's the only excuse for not having cab lights.
now a ladies man would have integrated cab lights with turn signals.
Old 10-07-2012, 10:26 AM
AbnMP13 AbnMP13 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Longhorn Laramie
AbnMP13 is on a distinguished road
Arth,
How complicated was dropping the headliner?
Brad made pics for the relays so even an Army guy like myself can wire them.
Whats the approximate spacing for the lights?
SFC, US Army
Retired
Old 10-07-2012, 12:12 PM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
I'm not Arth, but I'll answer your questions
The headliner is easy to drop. If you get the Recon lights is comes with instructions of how to drop it down. The Mopar lights come with a templete to lay on the roof and drill holes accordingly.
I just laid mine on the room and eyeball'd them. Then I spaced them exact with a tape. Its actually pretty simple once you get up there and do them.
MATT
Old 10-07-2012, 12:24 PM
Thanks Matt.
Anyone still have that template laying around?
SFC, US Army
Retired
Old 10-07-2012, 12:26 PM
Rep:420
No problem
Good luck finding one of those templetes
MATT
Old 12-18-2012, 08:42 PM
Matt, when you dropped the headliner could you see the backside of the overhead console?
SFC, US Army
Retired
Old 05-27-2016, 11:52 PM
TexasDieselGuy TexasDieselGuy is offline
Vehicle: 2003 Dodge Ram Cummins H.O.
TexasDieselGuy is on a distinguished road
Default Improved wiring diagram
I don't know who this person is that came up with that wiring diagram, but tell them to stop! It's terrible!
What is needed to operate the cab turn signal is an exclusive OR (XOR) gate. That means they light up when the signal OR the marker light is ON, but NOT when they are both OFF or both ON. Here's how you do it...
When using relays, you generally only use pin 30 for power in and 87/87a for power out of the NC/NO contacts. In this instance, the 87a NCs are not used and not shown. One side of each relay coil is connected to power from the marker lights. Then the other sides are connected to the Left and Right turn signals. This way, when either light is on, there is power on one side to close the relay, but when they are both ON or both OFF the relay is open because both sides are powered or grounded so the relay is open.
Old 05-29-2016, 01:00 AM
Default Improved wiring diagram v2
Added relay to power center lights and notes.
Also, this flashes outer cab lights with FOB lock/unlock command and turns 4-way flashers into 6-way whether the parking lights are on or not.
I'm working on making the center lights flash with the hazards too... but that is a little tricky.
Old 06-14-2016, 10:48 PM
How do I insert pictures inline instead of attaching them?
