Old 06-15-2012, 10:32 AM
Sport12 Sport12 is offline
Vehicle: 2012 Dodge Ram
Color: Dark Blue
Sport12 is on a distinguished road
Default Custom cai enclosure
Was thinking about making a custom insulated cai enclosure for my k&n intake. Anybody done thus or know how it turns out?
Old 06-15-2012, 07:35 PM
moparornocar72's Avatar
Rep:630
I think you would be better mating ur k&N tube up to the factory box and replacing the factory paper air filter with a k&N drop in air filter. Just my opinion but none the less if u do it post some pictures! Hope it works out for you!
14.268 @ 95 MPH Full Trim
Old 06-15-2012, 10:46 PM
Jchaney579 Jchaney579 is offline
Vehicle: 2012 Ram 1500
Trim Level: Lone Star
Rep:34
Jchaney579 is on a distinguished road
Been thinking about this also! If you take the rubber molding off the top and just get some sheets of metal then cut a square and weld it to the top. Then bend some steel or whatever you want to use and close the front off. Bend some also to get that little cut out on the fender that directs air into the stop air box closed off and aimed into the newly close K&N. Then paint and call it a day :P
Old 06-15-2012, 11:14 PM
Mophead's Avatar
Mophead Mophead is offline
Vehicle: 2012 2500 4x4 Crew
Trim Level: Bighorn
Mophead is on a distinguished road
How about a ram air tube or hose? Ala Pontiac Ram Air. Forced air can be a problem though.
See the CAI Evaluation thread. They're ram air'n. Didn't read all the way through though. I'm old school (carbs) so I don't know if the injectors will shoot enough fuel or not without mods??? Chrysler Racing manuals used to stipulate 35 sq inches for a scoop opening (carbs again). Haven't a clue the change in dynamics with throttle bodies and injectors. But you can bet your butt Ima gonna find out. I'm back in the game after a 30 year hiatus. Look out youngins!
Last edited by Mophead; 06-16-2012 at 12:08 AM. Reason: Saw another thread with suggestion
Old 06-16-2012, 06:59 AM
aaram12's Avatar
aaram12 aaram12 is offline
Vehicle: 2012 Ram
Trim Level: long horn
aaram12 is on a distinguished road
i left the rubber of and it looks great....dont see an engineering reason to have it exept for not burning my arms on a hot engine
Old 06-17-2012, 01:05 AM
storeboy storeboy is offline
Vehicle: 2009 Dodge Ram
Rep:19
storeboy is on a distinguished road
I have thought about doing this same thing, but I cannot find anyone that will sell just the tube. I already have the K&N drop in so I am set there. I also read a post about opening up the bottom of the factory box with a 3" hole saw and connecting a tube of flex duct right behind the bumper. I think between doing all of this it would help things out quite a bit.
