Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
tonneaucovered.com
Old 06-16-2012, 03:40 PM
jfreakofkorn jfreakofkorn is offline
Vehicle: 2001 Dodge Ram
jfreakofkorn is on a distinguished road
Default trans is slipping.....
I have a 5.2 with an automatic...
The question is:
That my transmission is slippin between 1st and 2nd.
Would be better to find another one or rebuild it....????
Old 06-18-2012, 01:13 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
The question is:
Rebuild it! It's is easy and inexpensive to rebuild these transmissions, a person who has never done it before can rebuild one of these in two days!
But before you jump into a money pit buying or rebuilding, first try to diagnose this issue, maybe it's something that can be repaired.
Slipping on the 1-2 shift or in just 1st gear. Could be a clutch issue however if it was a rear clutch issue you would slip in 2nd, 3rd, and 4th!
So the only thing to cause a slipping 1st gear is the overrunning clutch or an issue with the valve body. Now if it's slipping on the 1-2 shift it would be the front band that is the issue and would be corrected by adjusting this band.
Old 06-18-2012, 11:20 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I agree, tighten up the 1-2 band, hopefully, it hasn't been run this way so long, that it's no longer an option. The proper way to adjust this is NOT simply to crank the screw down, do a little history on this site and you'll find the right way to do it, crucial... This doesn't even require the pan to be dropped, it's an external adjustment. If I remember right, it requires a 1/4" torque wrench, tho I may be remembering the wrong adjustment. Good Luck!! (loose 1-2 shifts are generally the simplest fix you may ever encounter on this truck...)
