Old 06-17-2012, 02:32 PM
jfreakofkorn jfreakofkorn is offline
Vehicle: 2001 Dodge Ram
jfreakofkorn is on a distinguished road
Question 2001 1500 dash Whats the Deal.....
I just got the truck and seen the problems that it had.
Now I am going the list of fixing at what needs to be worked on.
So I finished with the engine problems, so i figured, I should start with the dash area.
Top of the dash is like gone ( from what I heard to was a bad start from the beginning ) and started replacing a switch and AC controls....
The minute I started to loosen the screws/bolts for the items on the dash, the back part of it started to break/crumble.....
Whats the deal with that.....????
Now i have to do is start super gluing the parts to the dash or get another dash carrier....
But I am afraid that I might run into the same problem once I get another dash carrier....????
Can anyone help at what to do now and are there an aftermarket companies that can fix this problem.....????
Old 06-17-2012, 03:37 PM
Rep:2664
The dashes were made of a plastic material that when exposed to the glare of the sun through glass, acted like someone using a magnifying glass, the sun, & soft plastic. It gets hard & then brittle.
Now they use a different type of plastic, it doesn't cook at 140 degrees F
Several companies are making dash caps or covers that are custom made for the different dashes
take your pick
http://www.google.com/#hl=en&sa=X&ei...w=1024&bih=550
Old 06-17-2012, 08:24 PM
How about a dash carrier...
The piece thats under everything that holds the cluster, ac controls, light switch, and so on......
That whole piece is like brittle/crumbling all underneath it also
Old 06-18-2012, 03:11 PM
blacknredram95 blacknredram95 is offline
Vehicle: 1995 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Black and Red
blacknredram95 is on a distinguished road
Check out my post on my dash replacement. My 95 cracked in half. I heard that the 98-01 dash was even worse.
Old 06-18-2012, 04:40 PM
Old 06-18-2012, 09:17 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
I think if you buy a replacementvash from lmc its about 225$ but it will have most of what your looking for as far as crumbled parts its the whole dash with the newer plastic made like the factory so it can go in as a unit. Yours is beyond useing a dash cap sorry to say.
Old 06-19-2012, 08:36 PM
Here is what my dash looked like after i pulled it out. Check out a junkyard first. The $225 LMC price scared me.
Old 06-19-2012, 08:38 PM
Guess the pic didn't upload. But try a junkyard first.
Old 06-29-2012, 02:28 AM
went to the dealership that they had on the other side of the city...
They gave me a quote for what I needed and goes as follows:
Panel-lower ( dash carrier ) 854.00
I/Panel-In ( dash upper ) 452.00
Bezel-Inst ( Cluster bezel ) 414.00
Total $1720.00
I ran across a guy that goes to auctions.
He says that he can like pick up trucks like next to nothing.
So I am hoping
Old 07-08-2012, 02:07 PM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
Vehicle: 2004 Ram 1500 quadcab 2wd
Color: tan
Rep:65
elinmon1976 will become famous soon enough
Most ALL of these trucks will have cracked dashes. And even if you pull one that is less cracked it may not make it through reinstallation. LMC has the dash, bezel, and reinforcement clips can be bought for less thank $500. You may find a cluster bezel in a parts truck but it would be a "unicorn" to find a good dash.
2004 Quad cab 2wd 4.7L
1998 Ram Reg Cab, 5.2 auto 2x4
Flowmasters to make her rumble...LOL
