Old 06-17-2012, 07:42 PM
BEX2010 BEX2010 is offline
BEX2010 is on a distinguished road
Question Help! Questions!
Hey yall... few questions!
-What is the purupose of a oil catch can? and pros and cons?
-What is a throttle body spacer? and pros and cons?
-What is the good and bad of upgrading the y pipe for a 2010 hemi?
and lastly...
-Any other MODS that are reccommended? Good/Bad feedback about anything?!?
Thanks!,
Bex
Old 06-17-2012, 08:28 PM
Rep:2625
the catch can captures the oil that your Smog System wants to put into your combustion chamber, by way of your throttle body
This gums up the throttle body, & then it goes down onto the pistons, the spark plugs fire & because oil can't ignite, it just cooks & makes carbon deposits on top of the pistons. None of that is good for your engine.
With the Catch Can capturing that oil, you don't have that issue. You just need to empty the unit at each oil change. I empty mine at 5,000 miles, it is right around 1/3rd full.
The Throttle Body Spacer just makes a whistling sound, it does not increase performance. In my opinion, they make good expensive paper weights
the Y pipe is flattened & round would be better, if you feel the pipe that passes by the transmission, it is also flattened, seems to me that is a lot of restriction
Old 06-17-2012, 10:46 PM
Thanks GTyankee-really helped!
I'll have to look into an oil catch can.. and possibly a y-pipe becuse yes, I have heard that they are very restrictive but would replacing it hurt the hemi that requires backpressure?
Your truck seems pretty nice and built up! If i may ask.. what does it mean to have it be wednesday built?
Thanks, Bex
