Old 06-18-2012, 04:44 PM
Bulldawg1359's Avatar
Bulldawg1359 Bulldawg1359 is offline
Vehicle: 2010 Dodge ram
Rep:25
Bulldawg1359 is on a distinguished road
Default Headlights other than Recon or Spyder?
Hey y'all I've been shoppin for some new headlights. I saw that spyder and recon lights have basically the same build, with the LED eyebrow thing. But does anybody have experience with Spec-D? or some other brands. I have been looking at them because they are cheaper, especially several I have found on eBay.
These for example: http://www.ebay.com/itm/270998943996...ht_2935wt_1396
I've seen seen these lights in different brands, but they all seem to be the same physically.
here is a video of the lights I'm lookin at,
Any opinions recommendations would be appreciated.
Cheers.
I just realized I did not post this in lighting. I am sincerely sorry and embarrassed...
White Lightning
My story - http://www.ramforumz.com/showthread.php?t=117311
Georgia on my mind.
Old 06-18-2012, 07:34 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
You an check out the AAC stuff as well. I dont know if they make anything for quad setups yet but their stuff is pry the best/brightest stuff in the inducstry
2011 Big Horn 4x4 -SnowWhite-
Old 06-18-2012, 07:57 PM
Rep:25
They do look neat. And I think they just came out with quads. Look here --> http://www.automotivelightstore.com/ramquadhalos.aspx
However i am not sure if i trust myself to do it myself, with the whole baking your lights ordeal. The ACC does look better though.
White Lightning
Georgia on my mind.
Old 06-18-2012, 08:15 PM
TheBlackHemi's Avatar
TheBlackHemi TheBlackHemi is offline
Vehicle: 2011 Dodge Ram Sport
Rep:111
TheBlackHemi will become famous soon enoughTheBlackHemi will become famous soon enough
Damn those are pretty cool looking, I just cracked open my quads to do a morimoto mini projector retro fit and I might have added those if I knew about it. As far as baking them the whole process and not hard at all, You have to be a complete dumbass to melt the lens/housing.
Peformance-HemiFever Tuned,Circle D TC,Mag 22" w/y-pipe &Raceland e-cut,Vararam CAI,87mm TB,JBA Headers,180T,& CatchCan
Appearance-2/4 BT drop w/airlift kit,F&R Hellweg SBs,PC'd 22" Boss 338s w/Nitto 420s,Pro HID 6000k,BW Flares,Undercover SE,Bestop PB,Led tails,Light Bar,CF Dash kit
Old 06-18-2012, 08:35 PM
Rep:25
Black Hemi do you think you could do a quick write up of how you did yours? Hope its not too much to ask. i dont know what path to take on my lights, but i really want them black. LED/Halos are my second priority.
White Lightning
Georgia on my mind.
Old 06-18-2012, 09:54 PM
Rep:111
Taking the lens off
1. Set the oven at 230
2. Throw the headlight in with the lens facing towards you (on a baking sheet)
3. Let it bake for at least 14-15 mins
4. Pull it out then slightly bend back the clear tabs that hold the lens and housing together (grille side)
5. Start at the bottom working to the top (grille side) and start to separate the lens/housing pulling up on the lens and down at the bottom. You can use either a flat head or butter knife...I went with a butter knife because it has more surface to wedge in between the lens/ housing.
6. If you can't separate them stick them back in the oven or use a heat gun to heat as you work upward on the grille side.
7 Once you got the grille side pretty much separated I would stick them back in the oven for another 5-6 mins.
8. Take them back out and then start pulling up on the lens and pushing back on housing and the rest should separate like butter.
Pretty simple... just don't force them open or try to pry it open with that butter knife. If you start to struggle opening them the glue is not hot enough....just stick them back in the oven for a bit or use a heat gun.
Old 06-19-2012, 12:48 AM
Rep:25
Alright thanks hemi. I will consider it. I just really want some black on my white sport.
White Lightning
Georgia on my mind.
Old 06-19-2012, 01:02 AM
Rep:111
Yeah the white with black combo is killer
Old 06-19-2012, 01:11 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Just remember go cheap and youll get cheap and do a search on here about baking them open every one has a different time its not as easy as you think i broke mine when i tried
Old 06-19-2012, 01:13 AM
dodgert's Avatar
Trim Level: rt
Rep:1061
What about the crap on the stock headlights its like j/b weld some say remove it some say dont id say remove it and use butyl to reseal its what i used on my aftermarket lights and its given me 0 problems
