bbk throttle bodie and headers - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram Special Edition Models > Dodge Ram R/T
Old 06-18-2012, 09:17 PM
christopher77 christopher77 is offline
Vehicle: 2005 dodge ram
Trim Level: rumble bee
christopher77 is on a distinguished road
Default bbk throttle bodie and headers
i have a 12 RT. and im thinking about these mods bbk throttle bodie and headers. has anyone done them and what was the gains? what one would be better 85mm or 90mm? i already have thje k&n cai.
Old 06-19-2012, 09:41 PM
moparornocar72's Avatar
Rep:630
the bbk might throw a code w/o a tune and since u cant tune that might create a problem
14.268 @ 95 MPH Full Trim
Old 06-19-2012, 10:22 PM
Rep:3347
Unless you have supporting mods you won't see much difference with the throttle body or headers unless you can tune it. Running my headers I threw a high O2 voltage code and it adjusts the tune down killing some power. If you run both you'll be throwing codes for sure and the engine will pull timing to compensate which defeats the whole purpose of the mods.
Old 06-20-2012, 08:12 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
In my opinion "bigger" throttle bodies are useless...the stock throttle body is 80mm, the inlet on the intake is 85mm. 5mm more isn't ever going to be noticeable, maybe I'm missing something but I would spend the money in other areas.
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
Old 06-20-2012, 08:41 PM
Rep:3347
Bigger throttle bodies aren't useless, but you should have the mods in place to take advantage of the higher volumetric flow rates. If you drop an 85mm onto a stock engine w/ stock exhaust then you won't see any noticable gains. But the same 85mm on a set of ported heads, cam, headers, etc will make a big difference as you are allowing more air at a higher velocity to enter and exit the combustion chamber. It is definately in the realm of supporting mods, not a standard bolt-on like so many people treat it. But we all know that the butt-dyno never lies.
Old 06-20-2012, 11:53 PM
Rep:73
well yea I suppose if you go into the engine internals and start messing around it could be beneficial, But like you said as just a bolt on accessory....not the greatest
Check em' out:
Old 06-21-2012, 12:12 AM
Grubrunner's Avatar
Rep:3883
On their own, yes, they are almost always not worth the money you spend.
However....
Bigger TB plus headers plus exhaust plus intake plus a custom tune [not canned] and you have a damn good combo.
I've used this method [and then some] on more than a few vehicles in the past.
Grub out!
Old 01-27-2013, 12:54 AM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
This is an old tread I did back in the day and everyone here was saying the larger throttle body was a waist of money, but now everyone is doing this so what gives???
SPONSORED BY
BULLY'S PERFORMANCE
Old 01-27-2013, 01:26 AM
Rep:3347
Because the highly modified guys are doing it, so everyone wants to do it. I have to laugh when I see people buying the "ported" TBs that still have a stock diameter butterfly valve. I can understand going to a full diameter TB, and with sufficient bolt-ons it can take advantage of the higher flow demands, but on a near stock motor it's still just one more thing for people to spend money on. Hell, we've at least curbed the throttle body spacer belief lately.
Old 01-27-2013, 01:36 AM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
So do you think Moe's 87mm throttle body would help me any with my mods of
K&Ncai / Ypipe / flowmaster / diablo trinity /hemifever tune / 180t / bt catch-can
SPONSORED BY
BULLY'S PERFORMANCE
