Are Bilsteins the number one way to level the new dodges? - Page 9 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
View Poll Results: Bilstein 5100s, Hell Bent, Daystar, ReadyLift ?
Bilstein 5100 220 86.96%
Hell Bent 18 7.11%
Daystar 11 4.35%
ReadyLift 12 4.74%
Multiple Choice Poll. Voters: 253. You may not vote on this poll
Old 12-17-2012, 11:44 PM
LoneWolfNY's Avatar
LoneWolfNY LoneWolfNY is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
LoneWolfNY is on a distinguished road
Originally Posted by Otterdriver View Post
I am surprised knowone has mentioned the Rancho Quickstrut, it is an R-9000 strut with the coil over on the strut as a complete unit, so you pull your factory coil and strut and set it aside, they are tuneable with 9 presets for dampening and rebound. Rockauto sells them for $158 aside. They raise the front end up to 2.75 inches. The coil is not compressed or loaded anymore than factory, the strut is simply longer.
Any info on those? I saw them too and was wondering if anyone is running them here,
Trinity, 180 Tstat, Magnaflow 18" muff no resonators, S&B CAI w/scoop, Bilstein 5100 Series Shocks all around, Billet Tech Oil Catch Can, AVS Vents, De-badged
Old 12-17-2012, 11:53 PM
LoneWolfNY's Avatar
I saw a member recommend getting the Bilstein kit threw Down South Motorsports for $359.99. On the page I noticed it says *Dodge Forum Members please contact us for discounts!!!* Is that this forum?
http://downsouthmotorsports.com/i-83...djustable.html
Old 12-17-2012, 11:55 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
These are very good units i do not personally run them on my truck but when i go to change my current struts out (probably 30k miles) i am going to put them on my truck along with the wireless kit if interested you can check them out in our online store here http://discountautoperformance.com/s...ancho-139.html we have them onsale right now for $205 each. A little more than the bilstein however it comes with a new coil and is complete, a bit easier to install for the DIY'er and still a very good reputable product.
Part Number: RS999930
Loaded QuickLift Quick-Strut
1.75 in. Lift
Compatible With myRIDE Wireless Controller
Includes Coil Spring, upper mount and strut
9 position adjustable
Rancho's Loaded Quick Lift is the quickest and easiest way to level the front of your pick up or SUV and eliminate the factory nose down rake. The Loaded Quick Lift includes the strut, coil spring and upper mount. It's fully assembled and ready for install. The additional ride height gained will allow you to add larger tires, up to 35 inches depending on application. The Loaded Quick Lift is also adjustable in 9 different positions allowing you to tailor the ride quaility to meet your rig's driving needs and it works with Rancho's MyRide Wireless Controller, which will allow you to make adjustments on the fly, from the comfort of your vehicle's cab, as driving conditions change.
Thanks
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 12-18-2012, 11:35 AM
LoneWolfNY's Avatar
Will it be enough to level truck though? Thanks for info so far
Old 02-16-2013, 09:38 PM
LoneWolfNY's Avatar
I installed the Bilstein kit and and couldn't be happier. Ride quality is better too, which surprised me since I figured it would be a stiffer ride with the spring being more compressed. The fronts are set on the highest setting btw.
I re-used the factory shock cover boots on the fronts. I noticed photos of other installs running them without them (you can see the chrome rod and yellow bumper exposed) whats up with that? When I took mine apart it was attached to the upper mount, so I kept it in place.
Old 02-17-2013, 11:37 AM
itshertruck's Avatar
itshertruck itshertruck is offline
Vehicle: 2016 Dodge Ram 1500 CC
Trim Level: Rebel
Rep:15
itshertruck is on a distinguished road
Send a message via AIM to itshertruck
I took the covers off when I installed my Bilsteins. I set mine at 2.1 and couldn't be happier!
If it's too loud, You're too old!!
Dodge the father and RAM the daughter!!!
Old 02-17-2013, 08:37 PM
Firebuff66's Avatar
Firebuff66 Firebuff66 is offline
Vehicle: 2017 Ram 1500
Trim Level: Sport-Night Package
Firebuff66 is on a distinguished road
Just wanted to say thanks for all the info here, you all have been a great help in
deciding what to get to level out my 2013 Big horn 4X4.
I pulled the trigger and went with 5100s all around with the front being the adjustable ones.
They should be here in a week, now to find a place to put them in. I will post Pics when they are done.
Old 02-17-2013, 08:45 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:165
Out of curiosity, how much for all 4?
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ EFI LIVE 75 HP TOWING TUNE/ OD TUNE
Old 02-19-2013, 11:44 AM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
Nice... you wont regret it. The ride improvement is worth it!
Old 02-19-2013, 07:39 PM
Grubrunner's Avatar
Rep:3883
Good job!
I went the identical route as you.... plus Moto Metal 951 Chrome 20" X 9" with Toyo Open Country MT's.
Truck goes in Friday.
I'm sure we'll both be wrapped!
Grub out!
