Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 06-19-2012, 09:27 PM
Hetzelmr's Avatar
Hetzelmr Hetzelmr is offline
Vehicle: 2002 Dodge Ram 1500
Color: blue
Hetzelmr is on a distinguished road
Default 2002 Ram 4x4 quad cab 5.9 PMs
I just bought this truck and it has 175k on the clock, runs like a top, no issues at all.
I'm planning on doing some PMs such as
Oil change
Tranny flush and fill(New tranny sump pan with drain plug and temp probe)
Coolant flush
The rear axle was redone at the dealership so I will change the fluid in the front one
Drain and fill the transfer case
Plugs, wires, rotor, cap.
Is there anything else I should look for while I'm down there. The CV boots are in good shape and I already hit all the grease zerks.
Old 07-15-2012, 04:37 PM
spockmckoy spockmckoy is offline
Vehicle: 2002 2500 ram
Trim Level: LT
Color: almond
Rep:19
spockmckoy is on a distinguished road
Have you looked down into the throttle body for oil residue? I just changed my plenum gasket, and I'm just under 54k on my 02' original engine. hughesengines.com makes it. Around $120 for the new kit and I changed my tstat down to a 180 degree one too.
Old 07-22-2012, 03:25 PM
Hetzelmr's Avatar
Color: blue
No I havent, but I'll crawl around and take a look.
Old 07-31-2012, 05:07 PM
fireman21 fireman21 is offline
Vehicle: 2013 Ram Big Horn Quad
Color: deep cherry Red
fireman21 is on a distinguished road
hey ive got same truck but mine has 223k on it now. (bought with 210k) in september of last year. anyway im looking for a new tranny pan as mine is rusted. where are you getting the new one from? does it take the same amount of fluid and sump as the factory? got a link? tranny was done last march so i should probably change the fluid as im not sure if it was ever done. thanks
oh and bw keep an eye on the timing chain gasket leaking coolant. mine leaked in the top corner intermittently sometimes worse than others. so i put a new pump on it and a new timing chain and gear kit on it while i was at it. i think all in all i spent 120 in parts. but doing the timing chain and gears while i was in there gave me that extra assurance that im not gonna have a problem in the future since it runs great now i wanna keep it that way
Old 07-31-2012, 10:07 PM
Trim Level: LT
Color: almond
Rep:19
Talking tranny pan
I found a pan online because mine rotted too. Keep in mind, the gasket is reusable. plastic with O-rings. I can't remember where I got mine, but if I think of it, I'll repost to here.......
Old 06-11-2013, 09:22 AM
jcurtis1313's Avatar
jcurtis1313 jcurtis1313 is offline
Trim Level: 1500 Sport
Color: Charcoal Grey
jcurtis1313 is on a distinguished road
Default miles!
Wow you guys give me hope! LOL. My 02 5.9 just rolled 108k miles and I was wondering how long I can make her last, since she is paid off I like not having a payment. You are over 200k without any serious problems,that's awesome! Considering I only put about 6500 miles on a year I should be in good shape for awhile.
Jeremiah Curtis
2002 Ram 1500 Sport
Old 06-11-2013, 09:33 AM
Troyw740's Avatar
Troyw740 Troyw740 is offline
Vehicle: 2005 dodge Ram 1500 5.7hemi 4x
Color: light almond pearl
Rep:16
Troyw740 is on a distinguished road
Last oil change 87955
Plugs 88000
Brakes done 88200
Brake fluid flush88200
Trans flush filter 88200
Diff oil 88900
Power steering flush 89000
Rotate tires 89100
Coolant flush 89500
All done with in the first 2k miles get her done my friend she will love u back
Old 06-16-2013, 12:38 AM
775carguy 775carguy is offline
Color: Charcoal
775carguy is on a distinguished road
i also have a 2002 quad cab 1500 with a 5.9. I have had it since 2003 and it had 23k or so on her. It now has about 150k and she runs great. I use Mobile 1 and only mobile1 for the oil. The only issue is it tends to burn or go thru oil. The Dodge dealer back in 09 or so said it was normal. I have done a 2 inch leveling kit, new shocks, cat back exhaust, Cold air kit and a tune up.I also put 2500lb overload springs on it when i bought it because I have horses and haul hay and such. She has been fantastic with no real issues to speak of. No regrets at all. I have also done the Thermostat and trans services,axles etc..My only real issue has been breaks. Aftrer 2 sets I finally ordered slotted front rotors and Heavy duty pads and i stopped going through breaks. knock on wood i havent had to do ball joints, tie rods, starter or anything.. I even used to run 315/70/17s and still no suspension issues. Im back down to a 285 and the wife still wants them smaller.
Old 09-17-2013, 04:44 AM
Hudson69's Avatar
Hudson69 Hudson69 is offline
Hudson69 is on a distinguished road
I just bought a 2002 Ram 1500 with the 5.9 V8, 4x4 and 190K miles. It ran great until I had the transmission flushed and now it runs horrible. I was told not to ever do that.... after I did it. You might want to ask your mechanic about that and just do an oil and filter change instead.
