Old 06-19-2012, 10:40 PM
76 Dart sport 76 Dart sport is offline
Vehicle: 1998 dodge ram
Color: purple
76 Dart sport is on a distinguished road
Default 98 ram won't stay running
I have a 98 dodge ram it idled fine but would die when giving it gas, I have changed the plugs and cap and rotor,the timing chain because it had a lot of slack, the crankshaft position sensor, I checked the fuel pressure,and it has 50 psi at the fuel rail, and I did a compression test and it had between 125 and 137 psi in all cylinders, and the plugs keep coming out wet and stink like gas, but I get plenty of spark, please help, I know the old 318 but not these newer ones, thanks, Scott
Old 06-19-2012, 11:00 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Possibly O2 sensors.
Is it any different at startup (cold)? Does it do better or worse once warmed up?
Old 06-20-2012, 12:11 AM
Color: purple
Default 98 dodge ram
it does better when cold, this morning it started andidled for a minute or so and then died when i gave it some gas
Old 06-21-2012, 12:07 AM
Rep:85
I'd be looking at the intake plenum gasket.
