TPS / IAC valve problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-20-2012, 12:07 PM
RhudeRam RhudeRam is offline
Vehicle: 2001 Dodge Ram
RhudeRam is on a distinguished road
Default TPS / IAC valve problems
2001 dodge ram 1500 5.9 360 v8
Alright, few days ago i had the symptoms of the TPS and IAC valve problems, no idle would stall if i did not keep my foot on the gas at stopsigns etc, however if i left it in park and kept it at 500rpm it would eventually stay running. At the same time i had a very weak battery, i had to boost it to start it.
Today i changed the battery and it has lots of juice, but now the engine wont start. i tried giving it gas because thats what would start it previously. Not working. I absolutly love the truck when it runs, i want to get it working more then anything its my first truck and im dedicated to find the problem if anyone can help me out i would be so greatfull
I havnt tried listening for the fuel pump to turn on yet with the key in the on position because it was driving a few days ago and it wasnt the fuel pump at the time.
I also was told it could be the MAP sensor for the original problem, but im now faced with it not starting at all.
Old 06-20-2012, 02:12 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2014 1500 Eco diesel/1982 D150
Trim Level: Outdoorsman
Color: Deep cherry red
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:21
Turn ignition key on and off 3 times after 3rd time leave in ON position if there's a code it will pop up in odomitor on left of cluster. Be quick to see code they don't stay up for long.
Old 06-20-2012, 02:17 PM
ramfam's Avatar
Rep:21
This can sometimes do a soft reset and allow you to start the truck by seting computer into limp mode.
Old 06-20-2012, 02:22 PM
ramfam's Avatar
Rep:21
Also if you find you have codes and have an android phone. Look in the market for OBDII trouble code lookup mobile . It is on the money and is a free app.
iac, idle, map, starting problem, tps
