Old 06-21-2012, 12:21 PM
zach27911 zach27911 is offline
Vehicle: 1996 Dodge ram
Color: Green
zach27911 is on a distinguished road
Angry Have to keep at high idle
I have a 96 ram 1500 I just bought yesterday and it had an electrical issue with the grounding, after i regrounded everything the truck starts up but theres one problem. I have to keep my foot on the gas pedal making it high idle when im driving, if i take my foot off the gas at all it dies. I thought at first it was bad gas since it was sitting for almost 3 months so i put new gas in and ran it through for about 30mins today and it still makes me need to keep my foot on the gas. I have no idea what I have to do, any suggestions?
Old 06-21-2012, 02:19 PM
Vehicle: N/A
Rep:1045
Check your negative terminal. I just snapped my negative cable connector, and used a clamp to hold it on till I got a new connection. Anyways, mine did exactly as you described. If there loose whatsoever it will do that too. Or any corrosion. A baking soda mixture with water will eat the corrosion .
Hope that's it cause its a simple fix.
Old 07-06-2012, 05:33 PM
gearbo gearbo is offline
Vehicle: 1994 ram 1500 pickup
Color: green
gearbo is on a distinguished road
MY 97 Truck would not stay running unless the idle was up ,soon as i let off, it died ,changed the battery problem solved ,low electrolyte level in a sealed unit and in fla a battery dries out in the heat of summer ,just a suggestion.... Bo
