Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 06-21-2012, 11:43 AM
Hhankthecrank Hhankthecrank is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Trim Level: SLT/ST
Hhankthecrank is on a distinguished road
Default roller tipped rocker arms
I came across an articale in the past that on stud mount rocker arms that you can use 1.6 or 1.7 roller tipped rocker arms for a Ch**y on a 2002 5.9 L gas engine ,has anyone heard of this, if so what brand and any special parts,Thank's
Old 06-21-2012, 02:49 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
CompCams screw in studs #4542-16 and guide plates #4825-8. Then you could use any chevy style roller rockers. Again, note those studs are 3/8". The stock Magnums are 5/16". So, there's a little work there. If you're not going wild with a cam swap, the stud upgrade isn't really cost-effective and you'd probably come out cheaper (all added up) just getting the (more costly) Mopar-specific ones for stock studs.
Old 06-24-2012, 02:33 PM
Trim Level: SLT/ST
Default Rocker arms
Thanks for the info
Old 06-24-2012, 06:08 PM
emjohn4 emjohn4 is offline
Vehicle: '12 Ram Sport CC / '02 Durango
Rep:154
emjohn4 has a spectacular aura aboutemjohn4 has a spectacular aura about
Harland sharp.
If you never plan on getting a cam, get the non adjustable roller rockers.
Get the 1.7 ratio. Gives a bit more lift and duration from the higher ratio.
I put a set on my 3.9 (318 minus two cylinders) - really woke the truck up. Best mod, period; for that series of engines.
You don't need the stud / guide plate / etc conversion, if you are keeping the stock rev limiter.
Old 02-18-2015, 07:54 PM
blu88's Avatar
blu88 blu88 is offline
Vehicle: 2001 dodge ram
Trim Level: Work
Color: saphire
blu88 is on a distinguished road
Digging up this thread,
looks like Scorpion 1022BL
1.72 ratio, pedestal mount.
If these work, then what about any small block ford roller rockers that use a pedestal mount or a 5/16 stud?
Powerlocked 456 dana60/70 on 37s w/ a 2inch coil spacer
Stock 5.9 sport
