Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Place your Ad Here!
Old 06-23-2012, 07:25 AM
dankent's Avatar
dankent dankent is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Trim Level: Laramie Limited
Rep:32
dankent is on a distinguished road
Default Kit arrived :) installing now
I have mounted the two airbags in the back, other then missing 2-3/8 nuts and 2-3/8 lock washer, everything else to be present.
I have a couple questions now, the drivers side airbag is close to the springs .. not touching but very close ... about 1/4 inch away (will it be ok?):
the passenger side is alot further but looking at where the top is supposed to contact the pressure would be on one side of the sand paper like matt, will that cause problems when under load or will the pressure of the airbag be able to keep it flat?
I now come to the wiring and installing the pump ... need to find a place for the pump, anyone want to share where they mounted the air pumps ? Picture would be grand if you have one
thanks all.
dan
Old 06-23-2012, 11:16 AM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default Nuts and Coil Springs
Dan,
Not sure why the nuts aren't there. Very sorry about that. We can send if you need.
As to the coils being close to the air springs, try turning the coil springs about 1/4 turn, this should solve that. You'll have to put truck on lift or jacks so you can easily turn the coils.
Here is a pic of where one customer installed the compressor - we've heard under the hood, behind the front bumper, on a frame rail. Many options.
John
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 06-23-2012, 11:48 AM
dankent's Avatar
Rep:32
No need, i raided my dads service truck for the nuts and lock washers Thanks for the picture.
Old 06-23-2012, 01:03 PM
dankent's Avatar
Rep:32
How about the shot where it contacts the edge of the pad, will that be a problem ?
thanks
Old 06-24-2012, 09:16 AM
dankent's Avatar
Rep:32
Well after a long day yesturaday, Its all done. put the center bezel back in this morning
Initial test last night I was loosing about 2lbs pressure an hour. So i decided to soapy water test all the connections.
Toggle switch copper lead pulled out when i removed one of the wires .. will need to find one of those, but its sitting in there loosely atm till i can replace it.
Had to re-tape the pump fitting as it was leaking, also had to remove the whole airbag from the drivers side ... lol figures, couldnt have been the passenger side.... But i had to re-tape that fitting as well. Also had alot of issues with the bleeder valve that after a couple re-tapes and a slight tossing accross the garage .. doesnt leak anymore.
So all in all it wasnt so bad, easy enough to do for a DIY'er.
Old 06-24-2012, 06:01 PM
TLC John's Avatar
Rep:17
Shot where frame meets pad is no problem when air is added.
Total Load Control™
Old 06-24-2012, 07:49 PM
dankent's Avatar
Rep:32
Ok thanks again. I have taken it out for a test run tonight. All seems well so far. Do people normally empty them right out or run some air in them all the time. What happens over winter, should they be removed?
Old 06-25-2012, 12:33 AM
TLC John's Avatar
Rep:17
Default Everyday Air & Winter Use
People seem to keep 3-6 psi as a minimum. With a bit more air you should find steering and handling improvement. Pretty much, this will be to your comfort and liking.
As to winter use, the air springs are rated for extremely low temps. Here is the official temp range from Goodyear:
-67F to 158F (which is -55C to 70C).
Total Load Control™
Old 06-25-2012, 10:16 AM
dankent's Avatar
Rep:32
Good news ok thanks alot for the help.
