Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 06-23-2012, 06:48 PM
ND RAM ND RAM is offline
Vehicle: 2011 Dodge 1500 Crew Cab 4X4
Trim Level: SLT Big Horn
Color: Mineral Gray
ND RAM is on a distinguished road
Default Change Oil Light
I've been getting the message to "Change The Oil" recently which is bogus because of the miles since I changed last.
I understand this has nothing to do with miles drive between changes.
However, to the left of the outside temperature display I noticed a symbol that looks like the number "1". I can't find any reference to this symbol in the manual.
When I went through the procedure to get rid of the "oil change" message, the number "1" disappeared also along with the message.
Any thoughts on this?
Old 06-23-2012, 11:43 PM
canamguy canamguy is offline
Vehicle: 2012 Ram Laramie Crew
Color: Deep Cherry Red
canamguy is on a distinguished road
I believe what you see as the "1" is actually the letter "I" which stands for "Information" which is telling you there is a message on your EVIC which in this case was "change your oil." Mine is showing the same message and symbol right now but I don't know how to get rid of it. I just changed my oil a couple of weeks ago and the message showed up a few days later. What is the procedure to get rid of the message or is it in the manual where I can look it up?
Old 06-23-2012, 11:50 PM
crazychevy88 crazychevy88 is offline
Vehicle: 2004 dodge ram
Color: silver
crazychevy88 is on a distinguished road
should be in the manual how to clear it, if not stopby or call your local quick lube. They know how to clear the oil change codes. I know em all up to 06, some are playing with the odometer (hondas) or pumping the gas pedal (chevy).
Old 06-23-2012, 11:57 PM
Bighert3rd's Avatar
Bighert3rd Bighert3rd is offline
Vehicle: 2011 Ram 1500 Sport (HEMI)
Trim Level: Sport (HEMI)
Rep:60
Bighert3rd will become famous soon enough
Turn ignition on, but don't start the vehicle. Pump the gas pedal 3 full times. Turn ignition off...message should clear. It's been a while since I did this, but I think that's the procedure.
Mods: Sport Hood-True Duals with Magnaflow 14'' mufflers-magnaflow 4'' tips-Magnaflow X pipe-Airaid CAI-PowerAid TBS-Truxedo Low Pro Cover-In Channel Vent Visors-22'' 2 Crave Wheels
Old 06-24-2012, 03:13 AM
Rep:2664
Yep 3 times, i believe it reads within 10 seconds
I change my oil at 5,000 miles, so i have to do it between oil changes, my light comes on just before i get to 3,000 miles
If you look in your manual, it reads either 5,000 or 8,000 miles between changes, UNLESS you run a Taxi or other Heavy Duty Service
Old 06-25-2012, 01:39 AM
Thanks for the info. I'll try it in the morning.
Old 06-26-2012, 02:01 PM
Rep:1804
This is exactly it.
Did mine 2 weeks ago.
Old 07-06-2012, 10:30 AM
drew7811's Avatar
drew7811 drew7811 is offline
Vehicle: 2011 Dodge Ram Laramie Crew
drew7811 is on a distinguished road
This is exactly it.
Worked on mine as well. My light just came on and this took care of it.
