Old 06-24-2012, 12:04 AM
blacklaramie98 blacklaramie98 is offline
Vehicle: 1998 dodge ram
Trim Level: SLT laramie
Rep:12
blacklaramie98 is on a distinguished road
Default Cocked out front wheel!!
Well my drivers side front wheel is cocked out pretty bad. The thing is that I have already replaced both lower and upper ball joints on that side and tie rods and drag link and yet it's still cocked out! Can't figure out what it is. Somebody help!
Old 06-24-2012, 11:43 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
What to you mean cocked out? !oo/ like sticking out at the top??
Do the brakes feel different at times? Did you check the hub bearing?
Old 06-24-2012, 10:20 PM
Rep:12
Like the bottom of it sticks out like a ball joint is out but We fixed them
Old 06-26-2012, 09:33 PM
94ramslam 94ramslam is offline
Vehicle: 1994 Dodge Ram 1500
94ramslam is on a distinguished road
Has your truck been lowered?
If it's not lowered it could be a bad coil spring or the upper control arm has slipped in the adjustment slots.
Old 06-28-2012, 09:38 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
2 or 4wd truck?
Old 08-22-2012, 08:12 PM
gman1951 gman1951 is offline
Vehicle: 1995 ram 1500
Trim Level: basic
Color: dark hunter green
gman1951 is on a distinguished road
I have a 95 1500 4x4 and had the same issue. I ended up relacing the ball joints and on the lower joint I put a 1 3/4 offset. I also had a bad hub assembly and replaced it with a new timkin. Now, life is good Camber problems resolved, no noise, and everything is tight
