View Poll Results: What colour should I paint my badges>
Matte black? 20 42.55%
Gloss black? 10 21.28%
Grey matching the rockers & flares? 12 25.53%
Red? 2 4.26%
Blue? 1 2.13%
Something else altogether?(explain) 2 4.26%
Voters: 47. You may not vote on this poll
Old 11-24-2012, 09:14 PM
Hardware's Avatar
Hardware Hardware is offline
Trim Level: Outdoorsman
Color: Black over Grey
Rep:31
Originally Posted by westers47 View Post
Plus 1 on removing them. Far too many badges on that truck. Keep it clean and simple. For the ones you can't remove I would go with flat black.
If you do paint them, there is no need to remove the badges. Just tape off an area about an one inch away from the badge, spray about 3 to 5 coats at different angels for coverage and then just peel of the paint on the body, the paint will stay on the badges.
This project got put on the backburner but I may try that...
Old 11-24-2012, 09:29 PM
Hardware's Avatar
Rep:31
On another note, anyone know where I can find Plastidip in Canada? Apparently it's not carried by stores anymore due to VOCs?
Old 01-03-2013, 10:06 PM
BigHornGreg's Avatar
BigHornGreg BigHornGreg is offline
Vehicle: 2012 Dodge Ram Crew
Color: Blazing Saddle
Rep:25
BigHornGreg is on a distinguished road
https://www.dipyourcar.com/pages.php?pageid=21 or check out kijiji.
Pretty pricey stuff to get in Canada.
Volant CAI, 85 mm TB, Magnaflow 16869, BT catch can, DIY cabin air filter, Line-X, Extang Encore
Old 01-04-2013, 08:36 PM
Hardware's Avatar
Rep:31
Thanks for the link!
Old 04-12-2013, 10:19 PM
Hardware's Avatar
Rep:31
I actually found a chain here in Ontario that carries it on the shelf.
I found it at Advance Improvements (I won't post a link but they're easy to find on-line) and picked up at their Advance Road store in Toronto.
The guy I dealt with at the counter knew all about Pastidip and spent 40 mins or so going over running boards and steps with me - no hard sell at all and wasn't perturbed in the slightest when I ended up not ordering any.
It's also where I got the PIAA headlamps (covered in a separate thread). Some of the best customer service I've ever experienced.
Old 04-12-2013, 10:27 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Unless you do like someone else did on another post here they took the badge off poured paind into the low area and left the Rems head chrome but the back ground is black that makes the Rams head pop out nice look
Old 04-12-2013, 10:34 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Hardware, what if you painted your crosshairs and emblem shield the grey like your fenders and bumper, and then black out your Ram emblem for contrast. This way it makes yours a bit different from others.
Old 04-13-2013, 08:00 PM
jdvelchek's Avatar
jdvelchek jdvelchek is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: R/T
Rep:86
jdvelchek will become famous soon enough
Excuse me if I repeat someone, I don't read past 1st pages. I'd go flat black on the front. It's easiest to tape off around the back since it is 3m'd on there and you can pop the front off with your fingers in 2 seconds. Great truck.
Old 04-20-2013, 10:31 PM
Hardware's Avatar
Rep:31
That's my current plan - once I get time to do it.
Old 04-27-2013, 02:05 PM
Hardware's Avatar
Rep:31
Finally...results.
Before...
After...
Before...
After...
I debated on PDing the High Output Diesel badge but figured it would look too featureless...if that makes sense. I also removed the dealer badge.
Still pondering on doing the side badges...
