Running rough - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-24-2012, 09:33 PM
acs dodge acs dodge is offline
Vehicle: 1994 Dodge Ram 1500 5.9L
Color: Green
acs dodge is on a distinguished road
Default Running rough
My truck starting skipping a couple months not a huge deal just a little annoying then a friend borrowed it and now it only runs smooth if its idling or to the floor. when keeping a smooth rpm above idle or decelarating it skips and backfires through the exhaust. I have changed the crankshaft sensor and the intake gaskets (wish I would have known about the hughes set) still the same Any help would appreciated
Old 06-24-2012, 09:47 PM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
Have you clean the throttle body yet? Very sample to do and does improve performance.
Old 06-24-2012, 09:49 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Reset the ECM to get it to relearn and try it then. Unhook the positive terminal and cycle the key once to do a complete power drain. Then re-hook it and take it for a ride.
DON'T check the codes afterwards, just re-hook it and take it for a ride. PM me after you do just that.
Old 06-24-2012, 10:55 PM
Color: Green
to warlock I cleaned the throttle body when I did the intake gaskets.... to paul when I did the gaskets the battery was unhooked the whole time I took my time doing this and then it got really hot so I didnt work on it for a while so it was unhooked for about a week.
Old 06-25-2012, 08:50 PM
Color: Green
So i did the reset no luck
Old 06-25-2012, 08:51 PM
Color: Green
just wish this thing would run right
Old 06-27-2012, 11:31 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2014 1500 Eco diesel/1982 D150
Trim Level: Outdoorsman
Color: Deep cherry red
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:21
Have you checked fuel pressure or injectors? Asd relay or fuel pump relay ? You did top end work so I think you can rule out distrib and wires and plugs. Oh did you look into O2 sensors and harness? Gm is good for running like poo when any number of those decide to go bad.
Old 06-28-2012, 12:26 PM
MoParPlowJockey's Avatar
MoParPlowJockey MoParPlowJockey is offline
Vehicle: 2001 Dodge Ram
Color: Burgandy
MoParPlowJockey is on a distinguished road
I had this problem after I changed the cap and rotor. Make sure your plug wires are ran properly. If not it causes induction and will run fine while idling. The is a tsb on it somewhere. I had it from another forum site and posted it on her and got warned. Basically the back two wires on each side can not be any closer than two inches. Good luck I spent three days working on mine til I came across the TSB.
Old 06-28-2012, 12:31 PM
Color: Green
What is the TSB?
Old 06-28-2012, 02:46 PM
ramfam's Avatar
Rep:21
Gms have a spark control modual in distributor that takes the place of vac advance. Wonder if that's TSB . I didn't think magnums had that.
