tonneaucovered.com
Old 06-28-2012, 03:05 PM
emjohn4 emjohn4 is offline
Vehicle: '12 Ram Sport CC / '02 Durango
Rep:154
emjohn4 has a spectacular aura aboutemjohn4 has a spectacular aura about
Originally Posted by ramfam View Post
Gms have a spark control modual in distributor that takes the place of vac advance. Wonder if that's TSB . I didn't think magnums had that.
The Magnum 3.9/5.2/5.9 has a cam angle sensor in the distributor (sometimes referred to a pick up coil or hall effect sensor).
The older 3.9/5.2/5.9 engines (pre '02, IIRC) had an issue with the cam angle target coming loose inside the distributor, and hitting the sensor, and causing erratic driveability. The OP may wish to investigate that.
The TBS was only informational for the spark plug wire routing.
Old 06-28-2012, 03:06 PM
Rep:154
Originally Posted by acs dodge View Post
What is the TSB?
Here it is:
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
